TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 01-26-2013, 09:54 PM
  #5551
R/C Tech Elite Member
LBR_Frank's Avatar
Originally Posted by AndrewTom View Post
1. Yes that combo does acheive 25* of kick. on a side note, the TLR 22 Chassis has a kick of 25* in the chassis.
so the 30* pivot essentially adds 5* of kick, and the buggy pivot with the other wedge/shim (which is labeled 20*) takes away 5* of kick given by the chassis.
2. I don't really know, but I think I remember hearing that with the aluminum pivot blocks, you don't need the brace, but i would keep it in until someone else can tell me wrong or right.
I ended up using the kit bracket as it fit just fine, everything lined up and not using it left too much space between the arms so it definitely needed something. For the time being it looks like it fine but if anyone can confirm that would be great! Thanks.
LBR_Frank is offline
Old 01-26-2013, 11:05 PM
  #5552
Casper's Avatar
Trader Rating: 34 (100%+)
You can use the 30 deg pivot brace with the 25 kick up pivot with no problems. You just can't use the 25/20 brace with the 30 deg block as it will interfer.
Casper is offline
Old 01-27-2013, 01:11 AM
  #5553
LBR_Frank's Avatar
Thanks Casper!
Old 01-27-2013, 06:57 AM
  #5554
Jokermayhem's Avatar
So during the trophy race yesturday mt truck was flying. TQ'd second in the first heat but truck got worse and worse as the night went on...12 hour day. I think I should have pulled off the sway bars as the track became dry and dusty. Any thoughts ?
Jokermayhem is offline
Old 01-27-2013, 09:44 AM
  #5555
I think you should consume more beer and stop being such a little girl on the track
pullinteef is offline
Old 01-27-2013, 09:57 AM
  #5556
I just fitted the front swaybar kit on my 22SCT without any problems but the rear sway bar does interfere with the installed rear weight (plastic part of the sway bar can not be bolted down because it is not seated/optional weight is too high). I run the 22 in mid motor configuration. Has anybody an idea what I am doing wrong or do these 2 parts just don't go together?
Thanks!
bashdj is offline
Old 01-27-2013, 10:06 AM
  #5557
I normally race on HIGH bite clay, but yesterday's race the track surface became somewhat dry...I also pulled off the rear sway bar, which definitely helped increase rear traction (left front sway bar on-white swaybar). Definitely noticed that it locked in the rear end, a little too much as the truck developed a medium push towards the middle of the main.
NPETRO is offline
Old 01-27-2013, 03:14 PM
  #5558
Dirtryder219's Avatar
Trader Rating: 58 (100%+)
Originally Posted by RC8daBOMB View Post
Any gearing suggestions for 17.5 Non boosted Reedy Sonic?
I run 78/28 on a Schuur Speed 17.5 w/35deg of timing on the motor and blinky on my Tekin. Motor temps after 5 min are under 130. Temps after about 7-8 mins are 150ish.
Dirtryder219 is offline
Old 01-27-2013, 05:08 PM
  #5559
AndrewTom's Avatar
I ran 25/78 on last sunday with 40* timing on a viper vst 17.5 blinky. I am going to try 26/78 and 30*, maybe 35*
AndrewTom is offline
Old 01-27-2013, 05:15 PM
  #5560
jpk4ud's Avatar
Sheared off the screw in the diff today..what a pain. I guess the way to go is replace it with the AE part?
jpk4ud is offline
Old 01-27-2013, 08:26 PM
  #5561
AndrewTom's Avatar
yup.
Old 01-27-2013, 09:10 PM
  #5562
mysupratoy94's Avatar
Trader Rating: 24 (100%+)
Does it matter which side the AE piston is placed in the shock? I have the number facing up...
mysupratoy94 is offline
Old 01-27-2013, 10:15 PM
  #5563
AndrewTom's Avatar
probably best number up so you can check what piston is in it, should you forget what is in the truck.
Old 01-27-2013, 10:55 PM
  #5564
Ok that's what I figured but didn't know I'd somehow the pistons were cut a certain way so they would flow inside the schock smoothly. Thanks
Old 01-28-2013, 06:56 AM
  #5565
spider882009's Avatar
Trader Rating: 7 (89%+)
Default Thank You!!!
Just confirmed what I was running with a Viper 17.5!!! I'm running 26/78 with 30*... It has been doing real well for me. Now if I could just figure out my TLR22 Buggy w/ a Viper 17.5 in it.
spider882009 is offline
