TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 01-24-2013, 07:21 AM
  #5506
Jokermayhem's Avatar
hmmm...ok. So the kit comes with a 30* pivot block right? So all I would need is a 0* front caster to complete the Dunsford/Casper setup correct?
Jokermayhem is offline
Old 01-24-2013, 07:46 AM
  #5507
Casper's Avatar
Trader Rating: 34 (100%+)
Correct
Casper is offline
Old 01-24-2013, 07:47 AM
  #5508
Thanks again... you the man !!!!!
Old 01-24-2013, 02:53 PM
  #5509
Originally Posted by F>T>R View Post
About how many weeks should you be able to run before you need to rebuilt the TLR ball diff?
For me it depends on motor size and how loose you need the ball diff to champion the track.
If your clutch can over power the ball diff and your ball diff barks on high torque then it won't last at all.
If you adjust your clutch to slip before the ball diff does then it will last a very long time.
6.5 turn motor, tight turn track loose ball diff = not good.
6.5 turn, open track big sweeps tighter ball diff = many weeks.
10.5 turn, open track big sweeps = a long long time.
It all depends...
If I could suggest a tedious task that is typically brushed off because most have low to no patients - after building a fresh ball diff start out with it tight and assure yourself the motor and clutch are not going to make it slip. And then start backing it off untill you're happy with the cornering and straights. Don't forget to back your clutch off so it always slips before the ball diff slips.
I will no longer run a ball diff with my 6.5 redline because my driving style and need for short burst blast offs will destroy the ball and race contact point quickly. So I use a gear diff with a 6.5. And since I'm a one track racer it is easy to find a likable diff oil weight, fill it and forget it. Now I use the gear diff on my 10.5 motor with 10k oil in it and I'm happy.
gmackhurry is offline
Old 01-24-2013, 03:01 PM
  #5510
gawith0413's Avatar
Trader Rating: 86 (100%+)
So what tires are you guys finding out work the best for indoor clay with this truck?
gawith0413 is offline
Old 01-24-2013, 03:19 PM
  #5511
Grandturk's Avatar
Clay rattlers on moist mixed clay surface have been dialed. Supersoft rattlers on drier dusty surfaces.
Grandturk is offline
Old 01-24-2013, 03:21 PM
  #5512
gawith0413's Avatar
Anyone run the Proline Ion's?
Old 01-24-2013, 04:10 PM
  #5513
F>T>R's Avatar
Trader Rating: 29 (100%+)
Yes, on high to med bite indoor track their great!
F>T>R is offline
Old 01-24-2013, 04:35 PM
  #5514
roberto_1029's Avatar
Can you use long lipos with the mid motor set up or do you have to use shorties?
roberto_1029 is offline
Old 01-24-2013, 06:24 PM
  #5515
+1^^^^^
Losi57 is offline
Old 01-24-2013, 07:59 PM
  #5516
who makes clay rattlers?
Old 01-24-2013, 08:06 PM
  #5517
ChrisWolfson's Avatar
I think that might be a Panther tire.
ChrisWolfson is offline
Old 01-24-2013, 08:39 PM
  #5518
Casper's Avatar
Panther tires.
http://panthertires.com/?page_id=42
Casper is offline
Old 01-24-2013, 09:45 PM
  #5519
Trader Rating: 60 (100%+)
TLR 22 sct Tranny help.
when i put my tranny back together it binds. i put the motor plate on tighten down the screws it binds some where in the diff area!! i back the screws off it quits binding.
Graphite07 is offline
Old 01-24-2013, 10:05 PM
  #5520
Grandturk's Avatar
Yeah you need to be careful when snugging up the tranny screws. You don't need to crank them down, tighten and check for free movement. That's pretty standard on most 1/10 off road trannies.
