TLR 22SCT Thread (Check First Page for FAQ & INFO)
#5417
I had the avid in my truck when I first got it. I'm running a 6.5 Reedy Sonic motor in it. It felt ok at first, but not great. Switched back to the stock setup and it felt better, but I never really liked how it felt. Then I switched to the AE VTS-4 slipper and it was exactly what I was hoping. The one problem with the AE slipper is that it has clearance problems with the gear cover. A little bit of dremel work and put spacers between the gear cover and motor plate, problem solved.
#5418
Well too know fault of the 22SCT's my idler gear went in my mid-motor set up!!! Stupid me when I built the kit I missed putting on the bearing that goes on the outside of the spur gear shaft. So it shredded the Idler after about 10 races. Re-built it last night with new idlers and bearings. Can't wait to put it back on track and upfront of the pack!!!
#5419
Guys,
For a loose rough dry track what aluminum hex sizes front and rear would you recommend stantard front an the 1.75 rear? Thanks
#5421
#5424
R/C Tech Elite Member
Just got my 22SCT done and took it to OCRC last night, was running solid 26's all night but would like to get down to 24's. Anyone used Casper's setup for the 22sct? Some of the guys said they were running his sheet verbatim with great success.
was going to post the sheet link... but I guess I have to post more on the forum.. PM me if you want the link.
Was just curious before I go out and buy tranny shims, buggy springs.. etc.
Thanks in advance guys, great thread!
#5425
If running the same tire all around try blue front springs like Ryan put on the setup sheet.
#5427
Losi 22 SCT newby here....came from 5 years as an SC10 FT owner. First off...can anyone send me the link to Caspers most recent setup sheet? Second I was wondering if there are any issues with this truck? Diff issues, Slipper issues, durability issues? Just wondering what if anything I need to do to keep this truck in tip top racing condition...thanks,
Dan
Dan
#5428
Dan
Dan
