TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 01-18-2013, 12:02 AM
  #5401
AndrewTom's Avatar
Originally Posted by Casper View Post
That is correct. It does two things. It give the link more clearance to get over the thicker alum arm when steering left. It also slightly changes steering expo as the servo sweeps.
by expo, does the truck have a more aggressive feeling or a more relaxed feeling. and shouldn't this mod give a little more throw?
AndrewTom is offline
Old 01-18-2013, 06:00 AM
  #5402
GNS Racing 86's Avatar
Originally Posted by TekinMan View Post
Has anyone tried the Avid Triad Slipper?
work awsome for me 13.5 motor, lots of guys using them at are track. havent heard 1 complant....
GNS Racing 86 is offline
Old 01-18-2013, 07:36 AM
  #5403
dirt42fan's Avatar
Trader Rating: 150 (100%+)
I have not tried them but they are hard like Pro-line. I would assume they would need to be sauced if you sauce other similiar clay tires at your track.
Thanks Casper, they do seem hard to me. Hate saucing tires...ugh!
dirt42fan is offline
Old 01-18-2013, 10:36 AM
  #5404
I have the ft associated in mine and liked it over the stock 22 clutch. There is more pad to grab in the associated than the stock. I felt you really had to crank down on the 22 clutch to get it to grab sooner.
slodustin is offline
Old 01-18-2013, 10:37 AM
  #5405
Casper's Avatar
Trader Rating: 34 (100%+)
I honestly have not put a ton of thought into it. I think Ryan said it would calm down inital steerin input. It should not effect overall throw but you should adjust that on the radio anyway to get to lock.
This is not a big change guys!
Casper is offline
Old 01-18-2013, 10:46 AM
  #5406
Originally Posted by Weaves1 View Post
It seemed to slip to much no matter how tight the nut was. It is in the garbage now. Don't bother with Avid.
i have used the triad, i'm not a huge fan IMHO. It had a lot finer adjustment, but I had issues keeping the slipper pads (which are PTFE, dont know if its a better material then stock) from glazing, even with minimal slip in 17.5 blinky.
i think that stock is fine, but I am thinking of trying out a Associated Factory Team clutch set, the VTS-4 or whatever its called.
Thanks for the input. I know this isnt an Avid thread but wanted to get input on people who had tried it on the sct.
I guess ill stick to stock.
TekinMan is offline
Old 01-18-2013, 12:14 PM
  #5407
Originally Posted by slodustin View Post
Thank you for posting your setup. I've checked out your track on youtube. Some videos the track looks dry and trucks are kicking up a rooster. Other shots it looks wet. Either way looks pretty loose.
Yes the early video that track was soaked and mud as it was new in the winter.
Now this track is hard packed and slick. Typically they will water it one time and not again for a while and its a dust bowl in there.
Check out this months new layout it is a very high flow fun track.
Attached Thumbnails TLR 22SCT Thread (Check First Page for FAQ & INFO)-jan12layout.jpg
gmackhurry is offline
Old 01-18-2013, 12:25 PM
  #5408
Originally Posted by tekinACE View Post
I found the kit set up on a similar track was pretty darn good with the right tires. My 11 yr old ran the Casper/Hacker set up this weekend at the crcrc midwest championship in ohio on a high grip track and the truck was very good he qual 5th and was gettin faster with every run.In the mains he had nothing but problems the truck kept cutting out Think i'm gona switch servos and receivers had this problem before.But the truck looked awesome in qual. He was running stock sct
Let me guess - savox and spektrum ???
I almost made it to the ohio midwest champs but couldn't break free. A few from our local track made the podium - that was pretty cool.
It's great to here your son is doing so well in 2wd.
Get a BEC and you can run whatever servo you want :-)
Old 01-18-2013, 01:20 PM
  #5409
Yep on the savox/spektrum. I'm gona try a HiTech servo and I upgraded from a sr300 to a DSM2 3100 Had this problem before added a glitch buster and its been fine sucked it acted up just in time for the mains.
tekinACE is offline
Old 01-18-2013, 01:27 PM
  #5410
Grandturk's Avatar
3100 rcvr or the $10 Orange DSM2 solves the savox/specktrum problem.
Grandturk is offline
Old 01-18-2013, 01:59 PM
  #5411
Carranza76's Avatar
+1
Carranza76 is offline
Old 01-18-2013, 02:01 PM
  #5412
hweaver184's Avatar
Trader Rating: 15 (100%+)
I wish i could find someone that kept them in stock!! I need to get 2 of them
hweaver184 is offline
Old 01-18-2013, 03:32 PM
  #5413
Do you have a current 2wd video link? What color is your truck?
Old 01-18-2013, 03:40 PM
  #5414
Carranza76's Avatar
Targethobbies.com
Old 01-18-2013, 11:34 PM
  #5415
Jokermayhem's Avatar
Default Well my switch from SC10 FT to Losi 22 SCT is complete....
Truck built and painted and ready to beat some Associated ass !!!!
Jokermayhem is offline
