TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 01-07-2013, 09:24 PM
  #5176
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by mysupratoy94 View Post
How do you accurately setup camber? After setting the correct camber and I turn the wheel or drop the truck I get a different setting.
You have to find an average and get it close.
Casper is offline
Old 01-07-2013, 09:40 PM
  #5177
Trader Rating: 90 (100%+)
Turn on the car and make sure your truck drives straight. Set camber, rinse and repeat if steering trim was WAY off.
Kuya_Kimo is offline
Old 01-08-2013, 01:14 AM
  #5178
dtr
dtr's Avatar
I roll the car slowly and slide the camber gauge along.
dtr is offline
Old 01-08-2013, 03:38 AM
  #5179
WIGMAN's Avatar
Trader Rating: 19 (100%+)
watch this video
http://youtu.be/OqtjxvBHGGk
WIGMAN is offline
Old 01-08-2013, 06:39 AM
  #5180
mysupratoy94's Avatar
Trader Rating: 24 (100%+)
Thank you everyone, lots of good tips on setting the camber.
mysupratoy94 is offline
Old 01-08-2013, 10:40 AM
  #5181
Which tools would you guys recommend for this truck? Im looking for metric tools and really like the Losi set but theyre kind of short and not sure if thats good or bad. Theres also a size in there that doesnt look like ill be needing so it may be a waste of money to get the set unless all the other sizes are actually needed.
TekinMan is offline
Old 01-08-2013, 10:56 AM
  #5182
Grandturk's Avatar
You'll need 1.5mm, 2mm, 2.5mm hex wrenches and an .050" for most pinion gears. You'll also need 7mm, 5.5mm and 5mm nut drivers. The 5mm is only for the slipper and you can use the "tamiya" wrench that's included.
Otherwise those are really all you need.
I also recommend the TLR turnbuckle wrench. It's sweet.
Grandturk is offline
Old 01-08-2013, 11:09 AM
  #5183
Casper's Avatar
Losi has a good setup of tools.
I am convinced MIP has the greatest tools out there.
If you are looking for longer tips Hudy are good but I wore out my tips. Yeah it took probably 7 years but I have never worn out an MIP tip and have had them longer.
Casper is offline
Old 01-08-2013, 01:58 PM
  #5184
maxx90's Avatar
Trader Rating: 104 (100%+)
Default mip
+1 on the mips
maxx90 is offline
Old 01-08-2013, 02:21 PM
  #5185
Team Tekin
Randy_Pike's Avatar
+2 on MIP.
Randy_Pike is offline
Old 01-08-2013, 03:14 PM
  #5186
Originally Posted by Casper View Post
Well first the SCT front camber block is 2mm higher then the buggy one.
Wow i did not know that. I thought the only differance was the mount for the sway bar. So is it different in any other way other than being 2mm higher?
I put on on my truck. So now i must have 5 mm shims on it.
Dale.0 is offline
Old 01-08-2013, 03:59 PM
  #5187
RC8daBOMB's Avatar
+3 on MIP
RC8daBOMB is offline
Old 01-08-2013, 04:31 PM
  #5188
Never had MIP, but have a full set of ED's tools.....Have not had one problem with them and have been using them for the past three years
NPETRO is offline
Old 01-08-2013, 05:43 PM
  #5189
GNS Racing 86's Avatar
i like the losi hex drivers, yeah a little short and pricey, but good quality, when you break a tip off in the head of a screw with some cheap drivers, you will really wish you had some quality hex drivers....
GNS Racing 86 is offline
Old 01-08-2013, 06:45 PM
  #5190
losiracer120's Avatar
Default Small screw in the toe plate
Has anyone had an issue of the small screw that goes in the rear toe plate when the toe plate is installed with the black motor guard it doesnt go in anymore any ideas what could not allow it to go in
losiracer120 is offline
