TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 01-02-2013, 05:49 AM
  #5056
???? I dont drive i'm just the pit crew for my 11 yr old so when I make changes its tuff to get feedback his response usually is GOOD or BAD LOL. What effect does less castor or more castor have? And moving the rear hubs forward?
My pit crew skills are not up to his driving skills and just trying to understand what the changes do. Thanks
tekinACE is offline
Old 01-02-2013, 05:54 AM
  #5057
Casper- do you or Ryan use any extra wings on the back of the 22sct high flow body with this new setup?
hartsbootsman is offline
Old 01-02-2013, 07:09 AM
  #5058
AndrewTom's Avatar
Originally Posted by Kuya_Kimo View Post
Spring rate progression... it'll start softer then as the spring gets closer, the spring rate gets tighter. I have tried the Kyosho, Avid, AE spring, and the Losi buggy yellow works real well with this setup.Thanks Ryan!
On another note, I finally have a setup I like with a shorty running 17.5 at a very competitive track. Now only if my driving skills can match how good this truck feels...
Ok, great! I am going to my LHS today to buy paint for my body (I had to mow a few lawns to get enough doe together!) and I will order the buggy yellow and buggy white too. I think I'll order that 22 diff wrench, TiNi front king pin, and the rear outer pin that eliminates E-Clips.
I don't like e-clips, but i respect their function as they have earned it!
Especially on my XXX-SCT.
AndrewTom is offline
Old 01-02-2013, 07:13 AM
  #5059
AndrewTom's Avatar
I'm still learning about the castor stuff, but I think moving the hubs forward (shorter wheelbase) gives you better forward bite, but less stability.
moving the hubs back (longer wheel base) gives you more stability, but less forward bite....
I think....
Old 01-02-2013, 08:01 AM
  #5060
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by AndrewTom View Post
Hey Casper,
Why do you use the Buggy Yellow rear springs instead of the Truck Yellow rear spring on your set-up?
is the shorter spring softer?
Both springs are the same "spring rate" but this is only one characteristic of a spring. The shorter springs have a bit more of a progressive feel so they feel like they support the rear of the truck as it compresses a little better feeling kind of like an inbetween spring.
No extra wings on the body. Most places don't allow extra wings but we do see guys try them from time to time.
Casper is offline
Old 01-02-2013, 08:39 AM
  #5061
AndrewTom's Avatar
okay, by in between do you mean its in between say the truck white and truck yellow? thats what I assume.
Old 01-02-2013, 09:10 AM
  #5062
Casper's Avatar
See this chart.
http://www.tlracing.com/Content/Medi...ring_Guide.pdf
Casper is offline
Old 01-02-2013, 09:20 AM
  #5063
losiracer120's Avatar
hey casper just put ur set up and ryans setup on my truck my only differance is my pistons your running 2 hole at 1.5 and 1.6 i ordered the 2 hole assciated piston kit to have but will my 55 4 hole work on a high bite carpet
losiracer120 is offline
Old 01-02-2013, 09:39 AM
  #5064
Casper's Avatar
55 is similar to the 1.6. You should go to at least a 56 or a 57 up front if using 4 hole pistons. The two holes will have much better pack characteristics for your hard carpet landings. Other wise 4 holes have similar corner handling.
Casper is offline
Old 01-02-2013, 09:44 AM
  #5065
ok thank you im going to try your set up for tonights race here in my local race track....
Old 01-02-2013, 10:33 AM
  #5066
cornerspeed's Avatar
Ryan and/or Casper, when you set the ride height on your trucks to 26.5mm, are you dropping the truck on surface from say around a foot, or are you just pushing down on the truck and checking it after it comes back up after it rebounds.
Doing it either ways results in completly different ride heights. Want to make sure I am doing it the same way you guys are doing it.
cornerspeed is offline
Old 01-02-2013, 10:39 AM
  #5067
Casper's Avatar
If your suspension is free it should not matter too much. We do drop the car 6 inches to a fool and let it settle and maybe tap the battery. Ride height should always be checked on a smooth flat surface like a glass counter top or similar as a towel or pit mat will be too grabby and with the tires not able to slide on the surface as the suspension moves you can get varying results as a resulte of that.
Casper is offline
Old 01-02-2013, 10:40 AM
  #5068
vito's Avatar
love the avid slipper kit
vito is offline
Old 01-02-2013, 11:02 AM
  #5069
acuratech's Avatar
Trader Rating: 27 (100%+)
Default how much slip
Originally Posted by Frank Root View Post
I just put my 1.5mm in the left outdrive and turn my throttle trim up to the slowest cog free speed I can get, for about 3 minutes, tighten and repeat until I hit my setting. I'll do something like mount tires or build shocks while it runs.
Frank How much slip do you tend to run on a very loose/sandy hard packed track.
thanks
Tech
acuratech is offline
Old 01-02-2013, 11:19 AM
  #5070
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
thanks
Tech
How much slip for the slipper, or the diff?
I try to have my diff never slip. You shouldn't be able to count the feet the slipper slips, especially in those traction conditions. If you can, the slipper is likely too loose. I hold my back tires down, and punch full throttle. The front tires should come off the ground about 1" for SC, and 2-3" for truck and 2wd for standard running conditions.
Frank Root is offline
