TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 01-01-2013, 08:32 AM
  #5041
Spork's Avatar
Originally Posted by Casper View Post
2 positions back. Basically you want it with one battery foam between the battery and the tower.
OK, great... thanks for clarifying. I'll give it another try.
Spork is offline
Old 01-01-2013, 08:41 AM
  #5042
The boy ran Hacker/casper set up in Indy this past weekend. He ran pro sc open with a 17.5 boosted an the truck looked very good he ended up finishing 5th in the a-main.The track was med-high grip and damp the truck seemed pretty hooked up The only thing I did not change was the castor block and the rear hubs were middle. If i go to say a 5 deg castor vs a 10 will there be more low speed turning and by moving hubs forward more forward grip less side bite correct? So far this truck seems to be pretty good no matter what you do!!! I do understand a 17.5 is easier to hook up than say a 6.5 but for my boy a 17.5 is way easier to drive and 5th out of 40 in pro sc open is a good day. Thanks for the help
tekinACE is offline
Old 01-01-2013, 09:00 AM
  #5043
AndrewTom's Avatar
just took it for a spin in front of my house, Very impressive. this corners so much better then my XXX. Gobs of steering, gobs gobs gobs of steering!
AndrewTom is offline
Old 01-01-2013, 10:31 AM
  #5044
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by rider313 View Post
Can someone get me the thickness of the shock shafts in MM please?
Thanks.
3.5mm shock shafts
Casper is offline
Old 01-01-2013, 10:40 AM
  #5045
rider313's Avatar
Trader Rating: 94 (100%+)
Thanks Casper.
rider313 is offline
Old 01-01-2013, 01:29 PM
  #5046
AndrewTom's Avatar
Hey Casper,
Why do you use the Buggy Yellow rear springs instead of the Truck Yellow rear spring on your set-up?
is the shorter spring softer?
Old 01-01-2013, 02:19 PM
  #5047
matt*strike's Avatar
Trader Rating: 41 (100%+)
Its about the progression rate of the springs. there is a difference between the buggy and truck that's why they use the buggy springs.
matt*strike is offline
Old 01-01-2013, 05:48 PM
  #5048
AndrewTom's Avatar
I get that part of it, but I am curious what he is getting out of the buggy spring that he didn't get out of the truck spring. I understand the buggy springs are shorter then trucks springs, but I am still curious
Old 01-01-2013, 05:53 PM
  #5049
vito's Avatar
hey firends am back uo to 150 lb all most there. i bin sick an not doing well but iam all most back to my self
vito is offline
Old 01-01-2013, 06:19 PM
  #5050
Potoczak's Avatar
Trader Rating: 120 (100%+)
Potoczak is offline
Old 01-01-2013, 06:54 PM
  #5051
AndrewTom's Avatar
Old 01-01-2013, 06:56 PM
  #5052
vito's Avatar
iam doing grate was down to 140 lb
vito is offline
Old 01-01-2013, 10:51 PM
  #5053
Default finished mine tonight
finished mine tonight almost "box art " but i like it , haven't taken it to the track yet ...:
professorjason is offline
Old 01-01-2013, 11:29 PM
  #5054
Trader Rating: 90 (100%+)
Spring rate progression... it'll start softer then as the spring gets closer, the spring rate gets tighter. I have tried the Kyosho, Avid, AE spring, and the Losi buggy yellow works real well with this setup.Thanks Ryan!
On another note, I finally have a setup I like with a shorty running 17.5 at a very competitive track. Now only if my driving skills can match how good this truck feels...
Kuya_Kimo is offline
Old 01-01-2013, 11:42 PM
  #5055
T. Herwig's Avatar
Trader Rating: 25 (100%+)
Looks cool. I like those colors together too.
T. Herwig is offline
