TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 12-15-2012, 11:37 PM
  #4786
Oasis's Avatar
Trader Rating: 38 (100%+)
Originally Posted by maxx90 View Post
Can someone point me to casper's clay set up? I checked front page and did a few searches for it to no avail. Thnx..
Look on petitrc..Casper's standard clay set up..= dialed..best set up for an 22SCY on clay I've tried..
Oasis is offline
Old 12-16-2012, 10:10 AM
  #4787
cobraman's Avatar
Thumbs up Casper's setup
It's posted on the first page, but here's a link:
http://www.petitrc.com/setup/losi/se...sper_20120924/
cobraman is offline
Old 12-16-2012, 01:20 PM
  #4788
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Oasis View Post
Wow..Casper your clay set up was "money".. really liked the way the truck handled, to bad the idler gear nuked in the main..
Glad you liked it. Sorry for the idler though!
Casper is offline
Old 12-16-2012, 01:35 PM
  #4789
BTW. I recently bought some new idlers. Back of the package said "rev. 1". Undated part? Hopefully!
nitroburnt is offline
Old 12-16-2012, 01:57 PM
  #4790
Hey guys, I've searched and looked through quite a few pages, so don't hammer me too hard. But I've read casper and a few other mentioning using the 14g tlr weights on top of the tranny, and was just wondering exactly where they were mounted. Any help would be appreciated.
jkilmurray is offline
Old 12-16-2012, 02:02 PM
  #4791
Nick@Jet's Avatar
Trader Rating: 17 (100%+)
The weights have 2 holes and you remove the two bolts ontop of tranny directly behind the shock tower - motor wires most likely are hiding the two screws
Nick@Jet is offline
Old 12-16-2012, 02:07 PM
  #4792
I thought that was probably where they went. Just didn't look like they would sit very well on there like on the 22.
Old 12-16-2012, 02:42 PM
  #4793
Oasis's Avatar
I honestly don't know what I'm doing wrong that's causing the idler gear to strip, I've had it strip out 4 times now, I've run both ball & gear diff with the same end result..so I'm under the impression that its the slipper settings that are putting a load on the idler gear..I don't have the slipper locked up, it does slip a bit, I have not had a problem with my other SC's (Durango & Kyosho SC-R)..the track I'm running on is a hi-traction clay track so that could have something to do with it..am I doing something wrong? Help..
Oasis is offline
Old 12-16-2012, 03:02 PM
  #4794
spider882009's Avatar
Trader Rating: 7 (89%+)
How do you install the weights on the mid-motor setup??? I have the TLR weights.
spider882009 is offline
Old 12-16-2012, 04:55 PM
  #4795
Casper's Avatar
I don't know. What is going on. I know TLR is aware of this though.
They screw on the back. Take out the rear two middle screws on top of the tranny and it hangs off the back.
Casper is offline
Old 12-16-2012, 04:58 PM
  #4796
AndrewTom's Avatar
have you tried a new transmission case? that seems to me to be something of easy fault. and it should be relatively straight forward to swap out.
Those teeth need to be in perfect contact for them to be efficient.
also do you run any lube in there? i used to use some black grease on the gears, but apparently thats bad, because i pulled apart my diff and all this black crap was in it. a few guys at my track said they run their trannies dry, but i dont understand that much, so i use a small amount of 20wt. shock fluid on the gears.
AndrewTom is offline
Old 12-16-2012, 06:24 PM
  #4797
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
Anyone have any input on the carbon fiber body mount upgrade?
kjohnsiii is offline
Old 12-16-2012, 06:35 PM
  #4798
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 106 (100%+)
I have them and they rock!
thecman26 is offline
Old 12-16-2012, 06:55 PM
  #4799
kjohnsiii's Avatar
Do they prevent the body from cracking?
Old 12-16-2012, 06:59 PM
  #4800
Having a problem with rear traction. The back end steps out on corner entry very abruptly. Running the kit setup with white sway bars front and rear, full pack all the way forward. I tried moving the rear shocks in on the tower and out on the arms and moving the battery back a little and it was slightly better but still had a really hard time putting power down. Im trying to get the back end locked in more. Things I was thinking of trying next time out are stiffer rear sway bar and thicker rear oil. Am I going in the right direction? Thanks
Mototech is offline
