TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 12-13-2012, 07:49 AM
  #4771
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
Agreed, i run stock and the shorty brings the truck to a different level!
kjohnsiii is offline
Old 12-13-2012, 08:03 AM
  #4772
DHooter's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Gas Rat Racin View Post
I'm having some idler gear issues. The first set lasted a pretty long time but the second set I striped one out in one practice night. When I put the trany together everything spun really nice. Any ideas?
when you replace them make sure to clean out ALL of the gear shavings from the stripped set. then put your slipper back to stock setting and tighten/ loosen accordingly to what you desire for your track. That should be the only reason for idler gear failures.
DHooter is offline
Old 12-13-2012, 08:18 AM
  #4773
Grandturk's Avatar
I need to mess with my weights when running 17.5 - I still run the same setup as mod - big battery, 1.5 oz behind battery, .5 oz behind servo.
Where are you running the shorty? Forward, middle, back???
Grandturk is offline
Old 12-13-2012, 08:35 AM
  #4774
kjohnsiii's Avatar
Running it about 1.5 inches forward and zero weight in the truck.
Old 12-13-2012, 09:30 AM
  #4775
AndrewTom's Avatar
quick question regarding the 22SCT and spindles.
i know it comes with 4mm trail spindles, but are inline and 2mm trailing spindles from the 22 buggy and truck cross compatible???
AndrewTom is offline
Old 12-13-2012, 09:55 AM
  #4776
Casper's Avatar
Trader Rating: 34 (100%+)
22T uses different spindles but you can use any of the buggy spindles. Buggies come in 2mm and in-line for your tuning needs.
http://www.tlracing.com/Search/Defau...erm=22+spindle
Casper is offline
Old 12-13-2012, 10:38 AM
  #4777
vito's Avatar
dose the gear diff have metal ones in side and what wight oil to get?
vito is offline
Old 12-13-2012, 12:52 PM
  #4778
yes
5000
kmags is offline
Old 12-13-2012, 11:48 PM
  #4779
Oasis's Avatar
Trader Rating: 38 (100%+)
I went through my whole truck and I understand why I hated it....omg ..I'm actually shocked it got around the track....mechanic fail on this one, I'm looking forward to racing it this Saturday with Casper's clay set up..
Oasis is offline
Old 12-14-2012, 12:45 AM
  #4780
ScottKelly911's Avatar
Originally Posted by Kuya_Kimo View Post
Anyhow, first night out with the truck and a random setup and it ran very well. As a blinky 17.5, I beat all the mod SC trucks and the normal fast guys came 1st/2nd... not bad for a new truck/class. I can't wait to get her dialed.
@Scott, thanks for starting the thread and most of all... Keeping the first post alive! Cya at WCRC or OCRC soon.
Wow Kuya you picked one up! Awesome, can't wait to see you at the track and talk setup! Cuda seems to really have his truck working well, so if you see him there, he's a pretty good person to bounce ideas off of. Not this weekend, but I'll probably be there the following weekend.
Originally Posted by theproffesor View Post
Thought I would share what Snowball the elf did last night.
Proof positive that even if you're an elf driving an RC car home from Santa's Workshop after a few suds, you shouldn't drink and drive!
Casper, time to edit that signature, you're not driving a XXX-sct anymore
ScottKelly911 is offline
Old 12-14-2012, 08:19 AM
  #4781
will g's Avatar
Trader Rating: 132 (100%+)
just have few ?'s about kick up and front hubs and caster blocks ... What does the diff kick ups do and caster blocks i seen 30 seams to be good # but some people set ups have them 5/25 - 0/30 - 10/20 what does this do to the trk and also last what would inline spindles do compared to 4mm trailing or 2mm trailing thnx Will G
will g is offline
Old 12-14-2012, 08:56 AM
  #4782
Casper's Avatar
Good catch. I was pretty good about fixing those and forgot to edit that one.
Casper is offline
Old 12-15-2012, 04:18 PM
  #4783
KalEl63's Avatar
I put the sway bar kits on the car yesterday and was surprised how much better it was with them on.
Now to start playing with some different front and rear springs and oils to see what does what.
KalEl63 is offline
Old 12-15-2012, 09:50 PM
  #4784
Oasis's Avatar
Wow..Casper your clay set up was "money".. really liked the way the truck handled, to bad the idler gear nuked in the main..
Oasis is offline
Old 12-15-2012, 11:14 PM
  #4785
maxx90's Avatar
Trader Rating: 104 (100%+)
Can someone point me to casper's clay set up? I checked front page and did a few searches for it to no avail. Thnx..
maxx90 is offline
