TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 12-12-2012, 07:12 PM
  #4756
Oasis's Avatar
Trader Rating: 38 (100%+)
Casper..on your clay set up I saw that your running 30deg and 0 caster, most of the set ups are 25 & 5..and what pistons are you using? On the 2 hole..thanks..
Oasis is offline
Old 12-12-2012, 07:18 PM
  #4757
Casper's Avatar
Trader Rating: 34 (100%+)
Yeah I like how 30/0 sits on the rear a little more. The setup has piston callouts.
Front 1.5mm 2 hole on 27.5wt and rear is 1.6mm 2 hole pistons on 30wt.
Or maybe you were asking how I got them. I made them.
http://losiracing.blogspot.com/2012/...e-pistons.html
Casper is offline
Old 12-12-2012, 08:00 PM
  #4758
AndrewTom's Avatar
Originally Posted by Grandturk View Post
You indicated that transmission is "quacking like a duck." That is the sound the differential makes when it is too loose.
the diff shouldn't really be tuned via turns out from snug... correct???
it should be set so it doesn't "quack like a duck" and from there for feeling is what i have been taught....right???
AndrewTom is offline
Old 12-12-2012, 09:50 PM
  #4759
Oasis's Avatar
Thanks Casper, just have to find the drill bits now..
Oasis is offline
Old 12-12-2012, 10:24 PM
  #4760
Grandturk's Avatar
Surprisingly this does work with AE diffs. That's how I set it on my b4.1 - easy peazy. The 22 diff takes more feel and adjustment trackside.
the AE big bore pistons also works if you don't want to make your own. I installed the 1.5 and 1.6 AE pistons in my 22sct and they work well. The truck does seem to settle quicker and does not become as unsettled over sharp impact rhythm sections. I'm still going to make some from TLR pistons to try out as well.
Grandturk is offline
Old 12-12-2012, 10:31 PM
  #4761
Outtacontrol58's Avatar
Trader Rating: 92 (98%+)
Arrow
What would be the most powerful blinky 17.5 gearing for a strong low end pull with great top speed? Thanks!
Outtacontrol58 is offline
Old 12-12-2012, 10:34 PM
  #4762
Casper's Avatar
mcmaster sells them.
Casper is offline
Old 12-12-2012, 10:47 PM
  #4763
ScottKelly911's Avatar
Oasis, the AE ones with Part #'s are listed on the first page. One of the benefits to the AE pistons rather than making them on your own, is that the flashing on the AE pistons come from the top so they're truly perfectly round as opposed to the TLR pistons that are attached to the parts tree from the side. So when you cut the flashing off the TLR ones, they're not "perfect" I know it could be fixed with sanding and careful knifework, but you can just buy the AE ones and not have to glue any holes and already have them perfect and ready to use out of the package.
ScottKelly911 is offline
Old 12-12-2012, 11:00 PM
  #4764
Gas Rat Racin's Avatar
Trader Rating: 37 (100%+)
I'm having some idler gear issues. The first set lasted a pretty long time but the second set I striped one out in one practice night. When I put the trany together everything spun really nice. Any ideas?
Gas Rat Racin is offline
Old 12-13-2012, 12:05 AM
  #4765
Oasis's Avatar
Thanks guys..you ALL rock, I'll try the AE pistons first (lazy..)..once again Casper thanks for the responses..we have met.. at the JBRL race in Bakersfield, last question..are you running shorty packs?
Oasis is offline
Old 12-13-2012, 02:28 AM
  #4766
Trader Rating: 90 (100%+)
Anyhow, first night out with the truck and a random setup and it ran very well. As a blinky 17.5, I beat all the mod SC trucks and the normal fast guys came 1st/2nd... not bad for a new truck/class. I can't wait to get her dialed.
@Scott, thanks for starting the thread and most of all... Keeping the first post alive! Cya at WCRC or OCRC soon.
Kuya_Kimo is offline
Old 12-13-2012, 06:58 AM
  #4767
theproffesor's Avatar
Trader Rating: 63 (100%+)
Thought I would share what Snowball the elf did last night.
Attached Thumbnails TLR 22SCT Thread (Check First Page for FAQ & INFO)-1213120630a.jpg
theproffesor is offline
Old 12-13-2012, 07:04 AM
  #4768
on a different note, how do you upload pics so that they are not thumbnails, but full size?
Old 12-13-2012, 07:22 AM
  #4769
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
I snap a pic from my phone. Upload it to my photobucket account. Then copy the image code into my post.
kjohnsiii is offline
Old 12-13-2012, 08:37 AM
  #4770
Casper's Avatar
I am running full packs in my SCT and 22T at this time but I run mod. If I was running 17.5 I would work on setting up the truck around the shorty pack as the 100g difference in weight is a big deal IMO.
Casper is offline
