TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 12-11-2012, 09:39 AM
  #4726
Originally Posted by vito View Post
http://www.amainhobbies.com/product_...Clutch-81T-84T
ok dose this fit under the stock cover
Yes, the avid triad clutch does indeed fit under the gear cover. I run one on my 22 sct, 22, AE b4.1 and b44.1 as well, awesome slippers.
adamym is offline
Old 12-11-2012, 09:41 AM
  #4727
vito's Avatar
thanks
vito is offline
Old 12-11-2012, 10:35 AM
  #4728
RShockley's Avatar
Yes the triad fits fine. It's the vts that doesn't fit under the cover.
RShockley is offline
Old 12-11-2012, 10:37 AM
  #4729
Grandturk's Avatar
Who needs a gear cover?
Grandturk is offline
Old 12-11-2012, 10:40 AM
  #4730
Casper's Avatar
Trader Rating: 34 (100%+)
The turn marshal who flips over your car for you and likes his fingers!
Casper is offline
Old 12-11-2012, 10:42 AM
  #4731
RShockley's Avatar
The marshalls
Old 12-11-2012, 10:53 AM
  #4732
Grandturk's Avatar
Originally Posted by RShockley View Post
The marshalls
You know this is true - and I was just joking (partially). I wear gloves when I Marshall nitro as well - because there's too many parts that can hut you on those things.
Old 12-11-2012, 10:56 AM
  #4733
Casper's Avatar
Yeah back in the days I ran nitro I would wear gloves to TM as I got burned too many times. Lots of moving parts and lots of very hot things to touch.
Casper is offline
Old 12-11-2012, 11:03 AM
  #4734
vito's Avatar
still cant get the slipper tight is bad. time to get a new set up or tires
vito is offline
Old 12-11-2012, 03:17 PM
  #4735
Butch Mann's Avatar
Trader Rating: 38 (100%+)
It's not a tire problem, keep the tires. Seek help at your local hobby shop or track where someone can diagnose the problem with you. It's hard to help you fix something we can't see or hear.
good luck
Butch Mann is offline
Old 12-11-2012, 03:26 PM
  #4736
Can just imagine what it feels like to get a finger stuck between a spur and pinion....probably close to when I got it sucked into a bench grinder..OUCH!!!!!
NPETRO is offline
Old 12-11-2012, 04:20 PM
  #4737
goehm's Avatar
Trader Rating: 45 (100%+)
If you really want to know, but not sacrifice a finger, then stick your thumb in there. It feels a LOT like that.
goehm is offline
Old 12-11-2012, 04:53 PM
  #4738
vito's Avatar
the lhe cant get it so i need help. the diff is tight the slipper is tight as hell it sounds like a duck on take off
vito is offline
Old 12-11-2012, 05:17 PM
  #4739
You need a gear diff my friend.
kmags is offline
Old 12-11-2012, 05:20 PM
  #4740
matt*strike's Avatar
Trader Rating: 41 (100%+)
Put a gear diff in it with some cleaning putty you will pull wheelies all day
matt*strike is offline
