TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 12-03-2012, 01:14 PM
  #4621
Trader Rating: 36 (100%+)
Originally Posted by wyd View Post
Do most of you guys run your caster blocks in spaced forward or back? I found on my SC and Buggy that I like them spaced back to shorten it a little and that I have more overall steering without my truck and buggy getting over steer. I know it worked in touring cars doing that so after I tried my current setups I then tried each one with the caster blocks in the back position and really like it.
I still run the spacer in the stock location, I just switched my kick angle and caster block to get more steering.
thefatkid is offline
Old 12-03-2012, 01:24 PM
  #4622
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
I did it to try and since my steering at the time felt good I kinda wanted to see how it felt so I move them to shorter position. I notice a tad more steering but not enough to upset my truck so I just kinda left them short after that.
I have not had the truck but for 2 weeks and and my new buggy only about 5 days so I just didn't get to mess around much with changing many things. Just wanted to run the base setup til I got good and use to it first.
wyd is offline
Old 12-03-2012, 01:29 PM
  #4623
Cloaked's Avatar
Trader Rating: 15 (100%+)
Quick Survey.
Plastic Servo Horn
Yes/No
Aluminium Servo Horn
Yes/No
Ball Cup Issues
Yes/No
Ball Cup Mod
Yes/No
Revised Ball Cups
Yes/No
If you guys could answer like this it would be appreciated (Makes it easier to tally).
Originally Posted by Cloaked View Post
Plastic Servo Horn
No
Yes
Ball Cup Issues
No
Ball Cup Mod
Yes
Revised Ball Cups
No
Cloaked is offline
Old 12-03-2012, 01:34 PM
  #4624
caguilar4's Avatar
Plastic Servo Horn
Yes
No
Ball Cup Issues
No
Ball Cup Mod
No
Revised Ball Cups
Yes
caguilar4 is offline
Old 12-03-2012, 01:35 PM
  #4625
wyd
Tech Legend
wyd's Avatar
Quick Survey.
Plastic Servo Horn
No
Yes (TLR Aluminum)
Ball Cup Issues
No
Ball Cup Mod
No
Revised Ball Cups
Whatever came in my new SC and Buggy I got in in the last two weeks. Not sure what the new vs older version is. 1st Losi's I have had in years.
wyd is offline
Old 12-03-2012, 01:39 PM
  #4626
Grandturk's Avatar
Plastic Servo Horn
No
Yes
Ball Cup Issues
Yes
Ball Cup Mod
Yes
Revised Ball Cups
No
Traxxass steering links installed after ball cup popped twice in one heat in Friday night. Very tight technical track with lots of rubbing = ain't got no time for no popping ball cups, fool!
Grandturk is offline
Old 12-03-2012, 02:03 PM
  #4627
stunter38's Avatar
Trader Rating: 73 (100%+)
Plastic servo horn
No never used
Aluminum servo horn
Always
Ball cup issues
Yes even with the revised ones
Traxxas on the way
stunter38 is offline
Old 12-03-2012, 02:16 PM
  #4628
juzza99's Avatar
I did ballcup mod, and they still popped off, most times I was looking for the complete camber link on the track.. It's weird as I've had the buggy since it first come out and never had any pop off, even with some massive wrecks..
Anyway, problem solved now with traxxax parts.
Loving the truck
juzza99 is offline
Old 12-03-2012, 02:25 PM
  #4629
goehm's Avatar
Trader Rating: 45 (100%+)
Plastic Servo Horn
No
Yes
Ball Cup Issues
No
Ball Cup Mod
No
Revised Ball Cups
Yes
Note: I've never had a revised ball cup pop off until yesterday when I told someone I didn't have problems with the revised ball cups popping off. I put the car on the track, grazed a pipe as I was going about 1/8 speed to head to the starting grid and off it came. No problems before or since then though - so the first rule of ball cup issues is to not talk about ball cup issues.
goehm is offline
Old 12-03-2012, 02:27 PM
  #4630
Plastic Servo Horn
Did at first, switched when it was time to replace the steering rack
Yes
Ball Cup Issues
nothing abnormal, popped 2 times on the old style cups directly related to crash
Ball Cup Mod
Yes, I did mod the 1st set
Revised Ball Cups
Yep, when they 1st came out, only put them on the 4 steering ends, saved the others for spares.
Mod steering rack for clearance
Yep, do that also. The new cups will still hit the rack on full compression.
Old 12-03-2012, 02:33 PM
  #4631
Grandturk's Avatar
This is true!
Actually I had been having very good luck with ball cups. Besides popping the first day I ran the truck I had very few incidents following until this past Friday. New track - tight and technical - and sure enough I piped it a couple of times. One cup popped the first Time. The second time the whole link went flying - so off came the ball cups and on went the traxxass links.
Time to finally do my 22T as well
Old 12-03-2012, 03:12 PM
  #4632
spider882009's Avatar
Trader Rating: 7 (89%+)
Got the mid-motor weight kit from TLR... Where do I bolt it in too??? LOL
spider882009 is offline
Old 12-03-2012, 03:44 PM
  #4633
RShockley's Avatar
The spacer is for switching between trailing and inline spindles. Run it behind the trailing spindle and in front of the inline spindles.
RShockley is offline
  #4634
Casper's Avatar
Trader Rating: 34 (100%+)
Does this help.
Casper is offline
Old 12-03-2012, 04:03 PM
  #4635
caguilar4's Avatar
Dunno what spacer you guys are talking about. Could someone post a pic plse?
