TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 11-29-2012, 04:23 PM
  #4561
Cloaked's Avatar
Trader Rating: 15 (100%+)
Originally Posted by goehm View Post
Fish tail you mean? Sure we might have messed up the whole football thing (LOL!!) but we got the tank slap thing down. That's on motorcycles when the handlebars slap from lock to lock (as if the bars slap one side of the tank, and then rotate to slap the other side, rinse and repeat).
This is what we call a tank slap:
http://www.youtube.com/watch?v=GvHtChodNk0
Fish tail is the rear end, when it goes back and forth like a fishie.
cheers
Yes we also call that a Tank Slapper.
I think we are getting off topic here
Cloaked is offline
Old 11-29-2012, 05:02 PM
  #4562
AlienModified's Avatar
Anybody switch from a standard size lipo to a shorty? What changes did you make to accommodate the weight transfer?
AlienModified is offline
Old 11-29-2012, 06:06 PM
  #4563
ach86's Avatar
Trader Rating: 45 (100%+)
I did but only for running this as a mid motor. I was not happy with my results running mid-motor as I have switched back to rear configuration. Many people are adding weight which tells me a shorty in rear configuration would be counterproductive.
ach86 is offline
Old 11-29-2012, 06:08 PM
  #4564
theproffesor's Avatar
Trader Rating: 63 (100%+)
I switched from shorty to standard. Like the standard better. This truck seems to really like the extra weight.
theproffesor is online now
Old 11-29-2012, 07:02 PM
  #4565
vito's Avatar
got my motor and esc all hook up thanks
vito is offline
Old 11-29-2012, 07:15 PM
  #4566
Grandturk's Avatar
No problem, bro. Anytime.
Grandturk is offline
Old 11-29-2012, 11:51 PM
  #4567
3D-Seth's Avatar
Trader Rating: 25 (100%+)
Originally Posted by driffter View Post
thanks for the reply.
the thunder power 2s 6500mah 65 c is what i've been looking at and will probably go with.
so how much run time are you getting ?
I honestly can't say. I don't personally have a 22SCT, but on my 17.5 Touring Car I get about 15 minutes before I need to charge. My 22 Buggy I get similar but I'm running a 10.5 in it. I would think that my TC would draw a little more mAh out of the pack since I'm probably running a little higher RPM than a SCT, but I can't answer that for certain.
Seth
3D-Seth is offline
Old 11-30-2012, 08:33 AM
  #4568
spider882009's Avatar
Trader Rating: 7 (89%+)
Having a on problem with the front end. My front hinge pins keep coming out towards the bumper. Do I have them in wrong or is there something suppose to hold them in??? Does anyone have a good pic of the bottom of the front end???
spider882009 is offline
Old 11-30-2012, 08:36 AM
  #4569
nitro_mt_racer's Avatar
Trader Rating: 230 (100%+)
You didn't install the set screws?
nitro_mt_racer is offline
Old 11-30-2012, 08:39 AM
  #4570
Unhappy OH!!!
I didn't get or completely missed the set screws!!! So there is set screws??? Wow Ive raced 6 times with this already and never noticed!
Old 11-30-2012, 08:46 AM
  #4571
Yeah, they go down thru the front pivot and lock into that groove on the hinge pin.
Old 11-30-2012, 08:59 AM
  #4572
Thumbs up Thank You!!!
I found it on the directions.... I hope I have them @ home. Is it the same set screw that adjusts the droop on the Ten-SCTE??? If so I have a whole bunch of them. I vote for color manuals!!! LOL
Old 11-30-2012, 09:26 AM
  #4573
You need an M3x5mm set screw, the scte droop screws are 10-32x3/8"
Old 11-30-2012, 09:58 AM
  #4574
Adonis_mp's Avatar
Trader Rating: 8 (90%+)
What is a good fighting weight for this truck, I hear people adding/taking/moving weight around.
Adonis_mp is offline
Old 11-30-2012, 10:10 AM
  #4575
Trader Rating: 36 (100%+)
Looks like you are mod so you can add more then I do with stock.
I'm at 7g on the tranny, aluminum front and rear ball stud mounts/bulkheads, and the 25 brass kick shim. I'm going to add the buggy aluminum front pivot here soon for just a little more front weight. Running a full size battery and 13.5 motor I feel I have enough rear bite right now with just 7g TLR weight. I have tried adding a little more and didn't notice much change. If I run a shorty I come in just under ROAR minimum weight and have to add some more. Then I do add to the rear for more forward bite.
thefatkid is offline
