TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 11-07-2012, 06:59 AM
  #4171
nitro_mt_racer's Avatar
Trader Rating: 230 (100%+)
Originally Posted by AndrewTom View Post
$16? that seems pretty high to me for sway bars.
LHS sold me mine for $10.
nitro_mt_racer is offline
Old 11-07-2012, 08:19 AM
  #4172
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by jmc23 View Post
Anyone?
Less Trail = More aggressive steering feel
More Trail = Less aggressive steering feel
IMO, not much difference in front end grip, just a change in steering feel.
Frank Root is offline
Old 11-07-2012, 08:20 AM
  #4173
Casper's Avatar
Trader Rating: 34 (100%+)
Can anyone explain the pros and cons of spindles I know the sct is 4 mm trailing what would be the pros or cons of changing to a 2 mm trailing spindle?
2mm trailing will make the steering feel more agressive/responsive.
Casper is offline
Old 11-07-2012, 08:21 AM
  #4174
Casper's Avatar
At least we said the same thing!
Casper is offline
Old 11-07-2012, 09:32 AM
  #4175
vito's Avatar
ok i just got the fronts bars thanks
vito is offline
Old 11-07-2012, 04:20 PM
  #4176
Curious... Anyone ran sway bars on a tight indoor track (med /high traction, hard packed dirt), rear motor. Did you like them? Are you running on both axles or just one, and which, if just one?
nitroburnt is offline
Old 11-07-2012, 04:25 PM
  #4177
Trader Rating: 14 (94%+)
i used them on carpet. Liked it better for sure!
Team T2C is offline
Old 11-07-2012, 07:21 PM
  #4178
vito's Avatar
ok how to set up my novak lp gbt2 esc settings . iam useing the stock settings and trun the drag brake off. motor is a 8.5 trun 540
vito is offline
Old 11-07-2012, 07:58 PM
  #4179
Thanks TEAM! Anyone else? especially dirt, rear motor?
Old 11-07-2012, 11:36 PM
  #4180
foxracing2006's Avatar
Was looking at the body braces. Are they any good? Worth the 30 bucks or no? Opinions?
foxracing2006 is offline
Old 11-08-2012, 03:02 AM
  #4181
jmc23's Avatar
Thank you for the response!
jmc23 is offline
Old 11-08-2012, 03:03 AM
  #4182
jmc23's Avatar
Thanks frank and Casper.
jmc23 is offline
Old 11-08-2012, 03:09 AM
  #4183
jmc23's Avatar
Default Ball diff
I took my ball diff apart no major wear in the rings and I have about 12 races on it . Just a slight groove.
jmc23 is offline
Old 11-08-2012, 06:14 AM
  #4184
so whats up w the sct set up sheet Frank?
hartsbootsman is offline
Old 11-08-2012, 09:39 AM
  #4185
Casper's Avatar
I run the swaybars on tight indoor tracks. I would get both front and rear so you have them for tuning. They do help this truck transition better left to right IMO which on a tight track will help.
Casper is offline
