TLR 22SCT Thread (Check First Page for FAQ & INFO)
#4051
Don't know about the SCTE ends but I'll tell you what does work well. I've posted this before, but things can get lost with over 4,000 posts on this thread. TRA3643 fit perfectly. They come with the tie rods and captured ends already assembled. You will also need four M3x12 screws to attach them. They do not limit travel in either direction and have been working for me and dozens of my customers for a couple months now. These are camber links for the Rustler and Stampede, so you know they can take a beating!
Less to worry about. I race it only I'd rather rip an a arm off then loose a dang ball cup and have it cost me the race.
I put 2mm spacers on both sided of the rear camber links for clearance and 2mm of spacers on the inner camber link up front for clearance.
Tie rods didn't require any clearance and I used 3x16mm button heads to secure them in the steering rack and steering arms with locknuts on the other side.
#4052
Question, and this existed before and after I converted to captured rod ends so I'm not sure where to adjust. I have noticed quite a bit of "bump-out" on the truck, how or where do I add or remove shims to help neutralize bump steer on this rig?
I tried on the rack and on the arms and didn't notice any differences. I'm running the 4mm trailing setup with 5 degree castor blocks, 25 degree kick shim setup.
#4053
Just rub the surfaces with a soft pencil. Quick, cheap and easy. Powder is available at any hardware or auto parts store. Try it, you may/will be surprised.
#4054
#4057
#4059
Finally, after over a month of having it being built, I took my truck to the track. IT WAS AWESOME! I'm running it mid-motor and had to add about an ounce of weight to the back to keep it from sliding, but once I did that, it ran like a charm. I was even passing buggies without bumping them. I could just slide right in front. I'm running an 8.5 revtech, with 86/19 gearing but am going to try 86/21 just to get that extra umph. Great job TLR
#4060
Need a little help fellas. Either the thrust washers that Losi put in this kit are complete junk or I'm building my ball diffs wrong. We have 2 trucks, and after every race (3q & 1m) we have at least one broken thrust washer on each truck. Last week I replaced a broken diff bolt & 2 broken thrust washers at the track before racing and then changed a broken thrust washer again tonight prior to this week's race.
On my son's truck I replaced the diff bolt, nut, spring, and thrust washers with the AE parts. On my truck I decided to test a theory and just changed the thrust washers to the MIP washers.
Any thoughts?
Any thoughts?
#4061
Any thoughts?
Any thoughts?
#4062
Yeah I know. I'm just trying to figure out if it's possible that I'm building the diff wrong. I can't believe that Losi continues to provide a product with such a high failure rate if my situation is common. At some point in time wouldn't quality control have went to the heat treater and said "hey, you gotta temper the thrust washers".
#4063
Now if my track can get some triad kits in stock I am nabbing one of them for my 22SCT! But thats another story altogether!
#4064
#4065
IDK, I have had a thrust washer disintegrate on me too, but only once (kit parts). My replacement is still in there. I am currently running 3 22 vehicles and have had one go out. I can't speculate as to why a lot of them have gone out on you. I run my slippers locked down and my diffs tight. If I have another one go out I am definately going the associated route.
