TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 10-30-2012, 08:46 PM
  #4006
vr6cj's Avatar
Trader Rating: 124 (100%+)
some pics of mine.
AE VTS clutch working great. you'll need the AE clutch spring and spacer too.
U will have to modify the spur ger cover. I cut it out and used the inner bead of a used tire to add to the depth. As seen on my 22. Stock cover wont fit.
vr6cj is offline
Old 10-30-2012, 11:44 PM
  #4007
Oasis's Avatar
Trader Rating: 38 (100%+)
Originally Posted by thefatkid
Under the servo, right behind the kick. Off of the transmission, take into account if your 1mm higher though.
Thanks..
Oasis is offline
Old 10-30-2012, 11:49 PM
  #4008
Oasis's Avatar
Anyone else having problems with the idler gear? I've tore up 2 and everyone in my area is having the same problem..I haven't had problems with the ball diff..and the slipper seems to be good..
Oasis is offline
Old 10-30-2012, 11:54 PM
  #4009
vr6cj's Avatar
ran mine a ton and zero issues. still have the stock 2 that came with kit. Some have though an found that they needed to replace the tranny case.
vr6cj is offline
Old 10-31-2012, 05:10 AM
  #4010
stunter38's Avatar
Trader Rating: 73 (100%+)
Is anyone running the new avid Slipper ?
stunter38 is offline
Old 10-31-2012, 05:18 AM
  #4011
Lucid's Avatar
Originally Posted by AlienModified
I'm using green painters tape for masking, will it hurt to clean it with alchohol between colors? I had a problem with residue from the blue painters tape I used the last time.
you should be fine to do that, just wait for the paint to completely dry before you clean it again
I clean my windows with alcohol after running and it hasnt messed with the paint
Lucid is offline
Old 10-31-2012, 05:20 AM
  #4012
Lucid's Avatar
how are you guys running your wires off the motors?
I soldered a buddys system up for him last night and I had to run the wires backwards away from the gearing to make sure it all fit, which I hate doing
dropping my powerplant in tomorrow
Lucid is offline
Old 10-31-2012, 05:54 AM
  #4013
Try replacing the out drives if your running the ones that came with the kit I know there were some defectives ones out there
Losi57 is offline
Old 10-31-2012, 05:56 AM
  #4014
Yessir it's awesome no problems here.best part is no more holding the pads in place while installing the spur gear.
Losi57 is offline
Old 10-31-2012, 09:30 AM
  #4015
ScottKelly911's Avatar
Originally Posted by kjohnsiii
Hey Scott, how are the sway bars working out for you on clay tracks?
Unfortunately I haven't gotten any swaybars yet. I'm hoping one of the tracks I go to or my LHS will have them this week so I can try them out. I did get a chance to run Casper's Truck for a battery pack at OCRC on Sunday. He has them on his truck and it felt much more planted than my truck does. I made some changes to mine and it was closer, but still not as planted as his. I have a feeling the Swaybars are the biggest reason why. I'll let you know once I get a chance to run the swaybars though.
ScottKelly911 is offline
Old 10-31-2012, 09:34 AM
  #4016
Casper's Avatar
Trader Rating: 34 (100%+)
OCRC posted they got some sets. Not sure if they sold out yet or not though.
Casper is offline
Old 10-31-2012, 12:38 PM
  #4017
Potoczak's Avatar
Trader Rating: 120 (100%+)
Hey guys my outdoor season has ended, and will be heading indoors on a high bite carpet track. What setup should I start with for a high bite carpet track?? Thanks!!
Potoczak is offline
Old 10-31-2012, 12:57 PM
  #4018
Trader Rating: 99 (99%+)
What is the benefit of running the two hole pistons?
isarctard is offline
Old 10-31-2012, 05:41 PM
  #4019
GVizzle's Avatar
They pack better on big jumps. Less bottoming out.
GVizzle is offline
Old 10-31-2012, 07:21 PM
  #4020
Trader Rating: 33 (100%+)
Who is everyone Mike? I haven't had an issue with mine.... I only know of 2 of the guys that have been having issues with the idlers, wonder if its because they are running like 6.5's in their trucks. I've just got a 10.5 in mine with a little bit of boost for the top end and haven't had a lick of trouble.
Wait wait, they both mentioned their slippers are basically locked tho, mine isn't near that tight. Bet that's why they are killing idlers....no way to dissipate the shock of a hard landing thru the slipper and its taking out the weakest gear in the transmission?!?
Ryan
rgirocz28 is offline
