TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 10-14-2012, 10:47 AM
  #3661
elecRC23's Avatar
Originally Posted by jammnjeff View Post
i see thatyou are running mid motor. so am i, but i dont have that thimg that you have your esc on. are you only using one strap because thats where ythe first battery strap is?
elecRC23 is offline
Old 10-14-2012, 10:50 AM
  #3662
vito's Avatar
will a 8.5 trun novak pull the front end up a lot? like to keep it down with the slipper
vito is offline
Old 10-14-2012, 11:03 AM
  #3663
SRC_DRIVER's Avatar
Trader Rating: 64 (100%+)
So I finally ran across the ball cup issues during yesterdays races. This was the first time I had ran the truck on a large outdoor track built for an 1/8th scale. I must say that I was very disapointed not being able to finish but one of my qualifers without a ballcup coming off and only one of the two mains.
I will be looking for captured ends or some other form of fix for sure. Are the turnbuckles off the XXX-SCT the same length as the 22SCT's?
SRC_DRIVER is offline
Old 10-14-2012, 11:43 AM
  #3664
chuckinator's Avatar
Originally Posted by rcracenut View Post
Does anyone have the part numbers for the sway bar kits for the 22 sct?
TLR334001-front
TLR334002-rear
chuckinator is offline
Old 10-14-2012, 04:01 PM
  #3665
easye's Avatar
Im ticked off the truck is awsome but Im eating up idler gears like there going out of style. Slipper is looser than Id like and forget tighting it down only will last a pack before it lets loose. And cant see how people are using avid tri slipper. Im at the point of jumping ship.Ive ran the gears dry if tried a little grease.
easye is offline
Old 10-14-2012, 04:21 PM
  #3666
kidmoneyoc's Avatar
Originally Posted by jpedersm View Post
Hey guys,
Local stadium truck field is dying and the short course is just getting bigger. I think I finally just talked my wife into letting me get one of these. My question is in my t4 I am running a castle creations sv2 5700. Would this work in this truck. I have seen that castle offers a sv2 sc version what is the difference? Also for the servo I am using is a Savox SC-1258TG will this work also?
I use the same servo and it works great... a little noisy though. Other than that, no issues with the 1258TG.
Good luck!
kidmoneyoc is offline
Old 10-14-2012, 04:33 PM
  #3667
I cant waite now. Going to get this kit tommorow, and this Sunday is the first race for this season indoors.
jpedersm is offline
Old 10-14-2012, 05:45 PM
  #3668
"Spanky's Avatar
Soooo ran the truck for the first time today..... FAST!!! Responsive as hell just a lot of body roll. Other than that great smooth and oh yeah FAST!
"Spanky is offline
Old 10-14-2012, 05:58 PM
  #3669
B00t13g's Avatar
To anyone running 17.5 what are you geared at? Ill be usually a triad and a tp 17.5.
B00t13g is offline
  #3670
AndrewTom's Avatar
try a new transmission case.
i have heard several people say that it solves the problem.
AndrewTom is offline
Old 10-14-2012, 06:07 PM
  #3671
AndrewTom's Avatar
Hey guys,
you may need/want either a RX capacitor or an external BEC. the savox servo's need at least 3 amps to function without any glitching, and the castle Sidewinder series of ESC's BEC is only 2 amps.
i have ran a cap at one time and then an ext. bec.
both do the same thing, but i prefer the bec because it eliminates the problem completely (bypasses the esc's internal BEC). while the cap can solve the problem too, it only masks the problem.
I found the ext bec to better because it lowered my esc temps about 5-10 deg. F. and the sidewinder series tend to run relatively hot.
Old 10-14-2012, 08:22 PM
  #3672
Do not jump ship! Call Horizon about this. They sent me a complete replacement transmission minus the out drives. Shortly after I blew up another idler gear. So far I have gone through 5 or 6. I TQed today in Columbus, OH with Losi drivers there so I am not a basher. After blowing up 6 I just replaced all the bearings in the transmission. So far so good. So if you talk with Horizon tell them to send bearings also or for 10 bucks or so you get some good ones at the hobby store. I am running an Orion 6.5 in mine also. My slipper is set to only slip for about 1 meter at the most from dead stop. I will keep you posted on how she holds up.
Losi 1972 is offline
Old 10-14-2012, 08:37 PM
  #3673
gifford450's Avatar
TLR 22SCT Thread (Check First Page for FAQ & INFO)-96f0d2f3-07d9-4a6e-a474-e636290cc767-9995-000008dcb19c077a.jpg
My lid
gifford450 is offline
Old 10-14-2012, 08:43 PM
  #3674
easye's Avatar
Ill call them.
easye is offline
Old 10-14-2012, 08:45 PM
  #3675
easye's Avatar
My spektrum lids.
Attached Thumbnails TLR 22SCT Thread (Check First Page for FAQ & INFO)-2012-09-05-11.28.43.jpg
easye is offline
