TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 10-11-2012, 09:09 PM
  #3601
caguilar4's Avatar
This might not be the place to Post this, but since it's the motor I run in my 22sct, Ill give it a shot.
How do i get can timing off of my Orion vst pro stock? (running 17.5 class)
caguilar4 is offline
Old 10-11-2012, 10:15 PM
  #3602
Registered User
Trader Rating: 6 (88%+)
Cool HELP
My 22sct is great and remarkable everywhere but when I jump i can't control the nose I will tap the brake as hard as possible but it kinda just floats in that position any help plz.
Rcdudes3475 is offline
Old 10-11-2012, 10:38 PM
  #3603
Is anyone running a 76 spur on their sct? If so, what pinion are using? I am running a tekin 17.5. Thanks!
heavypedal is offline
Old 10-11-2012, 10:40 PM
  #3604
trickedout's Avatar
Trader Rating: 31 (100%+)
76/26 max can timing on blinks mode.
trickedout is offline
Old 10-11-2012, 10:42 PM
  #3605
Thanks! Much appreciated...
Old 10-11-2012, 10:49 PM
  #3606
Also is blinks mode the same as blinky mode? Or did this auto correct?
Old 10-11-2012, 11:50 PM
  #3607
elecRC23's Avatar
you turn the endbell timing to the middle. Besides that, you adjust it from your esc.
elecRC23 is offline
Old 10-12-2012, 12:13 AM
  #3608
B00t13g's Avatar
Does anyone have a low- medium indoor setup?
B00t13g is offline
Old 10-12-2012, 02:39 AM
  #3609
KalEl63's Avatar
I know there has been some talk on here about shortys and normal batteries but what are most people running in their SCT and why?
I know most lean towards shortys in the 22 and 22T
KalEl63 is offline
Old 10-12-2012, 05:19 AM
  #3610
kevntri's Avatar
Trader Rating: 37 (100%+)
What motor?
I run a Trinity D3.5 17.5 with can around 20 degrees
Tekin RS in blinky
76/22 or 76/24 and run around 140 / 160 degrees in 6 or 7 min heats.
Could I be under geared?
kevntri is offline
Old 10-12-2012, 06:55 AM
  #3611
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
If your running mod sct, the full size pack is better in my opinion. It makes the track a lot more stable. I tested both packs last weekend and prefered the full size pack. Now stock, I would think a shorty would be a better decision.
Quad Racer 34 is offline
Old 10-12-2012, 08:00 AM
  #3612
Carranza76's Avatar
Originally Posted by Casper View Post
I run the 14g from the TRL tranny weight kit and then another 1.5 in the battery tray. I think dunford has gone up to 2 or 2.5 down there. The weight really helps the truck lay down the power in the rear.
what size motor you running?
Carranza76 is offline
Old 10-12-2012, 08:29 AM
  #3613
"Spanky's Avatar
Default THANKS EVERYONE
JUST WANTED TO THANK EVERYONE FOR QUICK REPLIES AND ALL THE GREAT HELP AND ADVICE DURING THE BUILD... OFF TO THE TRACK!!!
"Spanky is offline
Old 10-12-2012, 08:53 AM
  #3614
driffter's Avatar
hay guys I just bought a 22sct and wondering how this will work on an indoor clay track
Castle Creations Mamba Max Race Pro SCT 25.2V ESC + 1410 3800kV 5mm CSEC9600
I'm all ready running castle in a couple of other rigs so I'd like to stay with them plus they have always shone me great service in the past.
driffter is offline
Old 10-12-2012, 10:35 AM
  #3615
Grandturk's Avatar
What's up with those wheels!?
Grandturk is offline
