TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 10-06-2012, 04:57 PM
  #3451
That color is awesome. What is it called and who. Makes it?
fiveboyces is offline
Old 10-06-2012, 05:01 PM
  #3452
vito's Avatar
http://www.amainhobbies.com/product_...pray-Paint-3oz
vito is offline
Old 10-06-2012, 07:35 PM
  #3453
GreyBeard's Avatar
Trader Rating: 37 (100%+)
Default preload/ride height
Tony & Briguy-
Thanks for the info & help. It all makes sense now. Thanks again.
Pete
GreyBeard is offline
Old 10-06-2012, 07:44 PM
  #3454
Briguy's Avatar
Trader Rating: 125 (100%+)
Originally Posted by GreyBeard View Post
Tony & Briguy-
Pete
No problem , glad I could help !
Briguy is offline
Old 10-06-2012, 08:23 PM
  #3455
easye's Avatar
Any update on when the sway bar kit will be available?
easye is offline
Old 10-06-2012, 08:27 PM
  #3456
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
Fast Serve says the 22nd of this month. They should ship out that date so shops should have them a couple days after that.
Quad Racer 34 is offline
  #3457
Briguy's Avatar
Website still shows early November .
Briguy is offline
Old 10-07-2012, 03:42 AM
  #3458
ScottKelly911's Avatar
No. I am talking about the pre load collars. (Part Number TLR 5094 Shock Preload Adjuster Nut with O-ring)
It is the collar/nut that goes around the shock body, that holds the spring at the top. The spring is held at the bottom by the Spring Cup, Part TLR 5095
You adjust this collar up or down, the spring is relaxed or compressed it is called preload.
Other manuals show what the distance is from the top of the collar to the bottom of the shock cap.
I am getting kind of exasperated that I can't find the info. It is exactly like having a picture of a turnbuckle in a manual but no length shown. Put it together and use your own judgement about how long it should be?
Well, I called Horizon and talked with a nice guy in technical support. He knew what I was talking about but the final answer was he didn't have the info.
He went so far as to find a 22SCT that someone had put together, found some calipers and measured the front and back settings. But he didn't have the numbers as part of his technical info.
Can anyone help me? If I have sounded like I am ranting, I really appologize. It just seems like the numbers ought to be simple to find, not impossible.
Tony & Briguy-
Pete
Looks like you got the answer you were looking for. I don't know if you've had a chance to read the first post on the first page of the thread, all of the current setups are listed at the bottom of the first post. I know Ryan Dunford is also working on a new setup sheet, and I believe will have it ready very soon. Possibly after this weekend's Reedy Race at Hot Rod Hobbies. Once available, I'll post it. As Tony and Briguy said, the setups have the ride heights listed. Also, there's a lot of other really good info on there as well.
ScottKelly911 is offline
Old 10-07-2012, 04:38 PM
  #3459
elecRC23's Avatar
i just noticed that if i turn my tires all the way to the right, it locks there. the rod that connects the servo horn to the steering rack is going lower than the ballstud on the rack. I have to push the rod up so it can center again and go to the other side. Anybody have any clue as to what this might be or how i could fix it?
elecRC23 is offline
Old 10-07-2012, 04:57 PM
  #3460
There is nothing wrong. That is just the nature of the geometry. Turn your radio on. The servo will pull the rod up when it rotates.
kmags is offline
Old 10-07-2012, 05:30 PM
  #3461
nitro_mt_racer's Avatar
Trader Rating: 230 (100%+)
Adjust the end points of the servo via the radio. If the rod is below the ballstud you've already got all the travel out of the servo anyway....unless I'm looking at this wrong.
nitro_mt_racer is offline
Old 10-07-2012, 05:43 PM
  #3462
elecRC23's Avatar
yeah thats what i was thinking. thanks guys
elecRC23 is offline
Old 10-07-2012, 07:51 PM
  #3463
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 105 (100%+)
Just picked up my kit saturday!
Looking forward to another quality TLR kit build this week!
thecman26 is offline
Old 10-07-2012, 08:48 PM
  #3464
vito's Avatar
got my novak esc at the lhs its a gtb2 with 6.5 trun 540
vito is offline
Old 10-07-2012, 09:08 PM
  #3465
thecman26's Avatar
Wow, with a 6.5 that thing is gonna be a beast!
