TLR 22SCT Thread (Check First Page for FAQ & INFO)
#3436
Sorry I'm confused - when in my dash board it says "boost" for the timing advancement value of 80. I'm not mistaking it for "turbo" - I looked on the tekin web and it also shows the word boost. So I thought boost was the name they used for timing ? I think... now I'm confused LOL.
#3437
If your having trouble try READING the manual, they can be very helpful. also check out teamtekin driver setup pages...
#3439
got a new esc with the money i made its a novak gtb 2 thanks
#3441
#3442
#3444
Shock Pre load
This is probably a stupid question, but if I wanted to know what the settings were supposed to be for preload on the shocks, is there some place I could go to find that out?
First place to look is the owner's manual. It is not there. Second is a search of this forum. Doing a search of this forum for shock pre load and similar requests results in "no matches found".
Any suggestions for where I could find that information?
#3445
#3446
Shock Preload
No. I am talking about the pre load collars. (Part Number TLR 5094 Shock Preload Adjuster Nut with O-ring)
It is the collar/nut that goes around the shock body, that holds the spring at the top. The spring is held at the bottom by the Spring Cup, Part TLR 5095
You adjust this collar up or down, the spring is relaxed or compressed it is called preload.
Other manuals show what the distance is from the top of the collar to the bottom of the shock cap.
I am getting kind of exasperated that I can't find the info. It is exactly like having a picture of a turnbuckle in a manual but no length shown. Put it together and use your own judgement about how long it should be?
Well, I called Horizon and talked with a nice guy in technical support. He knew what I was talking about but the final answer was he didn't have the info.
He went so far as to find a 22SCT that someone had put together, found some calipers and measured the front and back settings. But he didn't have the numbers as part of his technical info.
Can anyone help me? If I have sounded like I am ranting, I really appologize. It just seems like the numbers ought to be simple to find, not impossible.
#3448
#3450
