TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 10-05-2012, 06:58 AM
  #3421
Trader Rating: 99 (99%+)
Originally Posted by Jimmy Lauri View Post
Could one of you guys that has an Orion VSTpro installed in their truck (rear motor config.) post a pic of it with wires from the esc? Its tight in my truck, i just dont want to do something foolish. Need some visual help. This is my first kit build...went awesome..love it! And im a newb to electric powered rc. I looked on the first page at Frank Roots truck....but you cant see were he has the motor clocked and you cant see any of the wiring and how he layed the wires in the soldering tabs. Thanks, Jimmy
Jimmy, here are a couple images of how I have mine wired up. I have not ran it yet, so im not sure my switch or capacitors are in the best location but I'm soon to find out, it was the neatest way I could come up with though.
Attached Thumbnails TLR 22SCT Thread (Check First Page for FAQ & INFO)-r10pro_vst.jpg   TLR 22SCT Thread (Check First Page for FAQ & INFO)-r10pro_vst_2.jpg
isarctard is offline
Old 10-05-2012, 07:09 AM
  #3422
hlb14's Avatar
Trader Rating: 28 (100%+)
one thing i haven't seen mentioned is are those of you who are running some of the aluminum parts are you using threadlock? i always did in 1/8 and did so on my durangos as well, just thought i would ask...
hlb14 is offline
Old 10-05-2012, 07:12 AM
  #3423
Briguy's Avatar
Trader Rating: 125 (100%+)
You definitely want to use thread lock on any screw going into metal . More so important is using the aluminum camber blocks as once the ball stud starts to loosen it will snap off .
Briguy is offline
Old 10-05-2012, 07:34 AM
  #3424
Grandturk's Avatar
Yep. Keep that little blue bottle handy. Anything going metal to metal gets thread locked.
Grandturk is offline
Old 10-05-2012, 07:56 AM
  #3425
hlb14's Avatar
kinda thought so, is losi's stuff any good or is a name brand the way to go? i ask because i built a durango once with the supplied threadlock and it sucked! had to take it all apart clean and reassemble
hlb14 is offline
Old 10-05-2012, 08:12 AM
  #3426
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
The Losi-Lok is all I use, it works great. It is usually a good idea to spray off steel parts/hardware before applying threadlock as they have an anti-rust coating which inhibits the threadlock from drying directly to the surface.
Frank Root is offline
Old 10-05-2012, 08:16 AM
  #3427
TLRacing
Frank Root's Avatar
I tried to upload an image, but no such luck, keep getting errors.
Old 10-05-2012, 09:01 AM
  #3428
Originally Posted by kmags View Post
I may have misunderstood but my Tekin does not allow 80* boost in sensored only mode.
The timing on the far left of the timing screen is for timing for unsensored motors or when in "dual" mode.
The center timing panel with the start and end rpms is for sensored only boost. And on the right is the afterburner (sensored only).
Correct - I have the vegas software and the only change is that I changed from 80 to 20 boost. Meaning i'm still in default C2 dual mode I just slide the boost bar down to 20 and applied it.
I mentioned that I used to run in sensored only.
While I'm here... When in sensored only do you have to first put the boost timing to 100 and apply it before you switch modes? Maybe wrong thread but if you know.
Thanks.
gmackhurry is offline
Old 10-05-2012, 09:22 AM
  #3429
weavty1's Avatar
Thumbs up
You did it right
Dustin Evans has his mounted the exact same way.
So, good job sir!
weavty1 is offline
Old 10-05-2012, 09:28 AM
  #3430
Grandturk's Avatar
Originally Posted by weavty1 View Post
You did it right
So, good job sir!
Those are some interesting carbon fiber body mount braces. What's up???
Old 10-05-2012, 09:29 AM
  #3431
weavty1's Avatar
Not made my TLR, that's all I can say as of this time
weavty1 is offline
Old 10-05-2012, 09:34 AM
  #3432
Talking Perfect! Thankyou!!
That is perfect man!! Thankyou very much. Thanks Frank for trying..no sweat! I like to thank all of you for responding. Jimmy
Jimmy Lauri is offline
Old 10-05-2012, 09:46 AM
  #3433
Casper's Avatar
Trader Rating: 34 (100%+)
Thanks.
Tekin does not boost to 80! You can only go to 80 setting in advance timing and that is only for dual or senorless mode. That is why we are all confused!
I bet those are JC Monroe parts.
Casper is offline
Old 10-05-2012, 09:51 AM
  #3434
Grandturk's Avatar
Careful WeavyT - they stole your spring chart. I'd be afraid of TLR stealing your prototype body mount braces as well!
j/k folks
Old 10-05-2012, 09:56 AM
  #3435
weavty1's Avatar
j/k folks
Bahahaha, noo noo.. Frank asked to use my spring chart, and mentioned me on the blog. Haha, no harm, no foul!
As for the body mount braces, lol.. That's just an illusion - It's swamp gas. Nothing to see here, move along.
weavty1 is offline
