TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 09-24-2012, 04:39 AM
  #3151
Cloaked's Avatar
Trader Rating: 15 (100%+)
Thanks for everyone that had suggestions with my Diff.
Turns out it just wasnt tight enough!
I tightened the diff up about 1 complete wheel turn and the barking stopped, car seems a fair bit faster now as well.
Cloaked is offline
Old 09-24-2012, 04:42 AM
  #3152
Briguy's Avatar
Trader Rating: 125 (100%+)
If it was that loose you mind as well rebuild the diff now . Once you let the diff bark and slip flat spots have created on the diff balls .
Briguy is offline
Old 09-24-2012, 04:44 AM
  #3153
Cloaked's Avatar
Will do once my B-Fast Diff balls get here.
At the moment got nothing to replace them with.
Oh well Ill run it till it busts.
Cloaked is offline
Old 09-24-2012, 06:06 AM
  #3154
fastford's Avatar
Originally Posted by Guch View Post
It's not wearing in I'm worried about, it's wearing out is when I think things will get worse. My ball cups are so tight I still have to use pliers to snap them and I have the ninja grip. You should of seen the corner marshel trying to snap my ball cup back together. He had to press the truck against his hip and grit his teeth. And he was a big guy. Still investigating even going to captured ends from a different vendor. At least the outer ends.
I feel your pain ran AAA mains and the first 2 my ball cup came off. JR Mitch had one pop off in the mod Main also. Aside from that I love this truck.
fastford is offline
Old 09-24-2012, 06:25 AM
  #3155
Kass's Avatar
Trader Rating: 42 (100%+)
Why does the new proline chassis for the traxxas slash look so much like the TLR 22SCT?
Kass is offline
Old 09-24-2012, 06:27 AM
  #3156
Briguy's Avatar
Because they copied it .
Briguy is offline
Old 09-24-2012, 07:10 AM
  #3157
Carranza76's Avatar
my first race with the truck (club race) and I loved it man it has im proved my lap times a lot. Running Losi 13.5 with a Tekin RS and Spektrum 6040.
One of the local guys who usually laps me in about 4 to 5 laps didn't get to lap me at all and he was running a 22SCT also. Man this truck hooks so well. Can't wait for the sway bar to come out it can only improve it.
I have a Spektrum DX2S and my steering wheel spring broke anyone know of a good tutorial for the fix? I am gonna switch radios now after this but I would like to fix this one for my son to upgrade him.
Carranza76 is offline
Old 09-24-2012, 07:41 AM
  #3158
elecRC23's Avatar
Originally Posted by AlienModified View Post
Mine came with the kit
where were they in the kit? maybe i just havnt looked hard enough.
elecRC23 is offline
Old 09-24-2012, 07:49 AM
  #3159
Trader Rating: 36 (100%+)
If I remember right, bag e. They were in with all the stickers and manuals. About a 5"x5" square.
thefatkid is offline
Old 09-24-2012, 07:54 AM
  #3160
Trader Rating: 31 (100%+)
Originally Posted by adubaz7 View Post
Hey guys I have a big race coming up next weekend and need a little help on tire choice. I am running in a series that is going to an indoor hard pack track. I ran out there both friday and yesturday and the kit setup seems to work pretty good for me with just a few small changes but mostly all kit setup, the race director for some reason waters the track very lightly between almost every race. When he waters lightly then runs a heat and another without watering and then I am say the third race and he doesnt water my truck works great with HB beams on the rear and proline square fuzzies on the front, the stearing is a little aggresive in the bumps but I am going to try blue barcodes on the front to smooth out the steering but my main problem is if I am the race up right after he mist the track I cant find a tire that will work on the rear everything is just slick as hell for at least the first third of the race and even by the end of the race it is only ok traction so I am having to hold back so much. Please give any suggestion for a tire that works on a very hard pack smooth track just after a very light sprinkle
Does anyone have a suggestion I saw one say maybe suburbs but I doubt it because I have tried the other beam type tires and they work when the track isn't moist but slide all over right after being watered. I have very little experience with this hard pack indoor with water on it type track but I know a lot of you guys only run the hard pack indoor type and understand most of the time you run it is probably dry but what do you put on if your up right after the track is sprinkled
adubaz7 is offline
Old 09-24-2012, 08:08 AM
  #3161
To All, If you contact customer service at Horizon, they do have the updated ball cups to send out now. This will help some. Second, once one pops like this, because of the way they pop, it stretches the cup length wise. This makes it feel hard to pop on, but will come off easier in the long run.
Also, I suggest grinding the hex portion of both ball studs on the inside and outside. After I did this and put fresh ball cups on, havent had any issues at all.
hacker07 is offline
Old 09-24-2012, 08:35 AM
  #3162
theproffesor's Avatar
Trader Rating: 63 (100%+)
Are the ball cups free?
theproffesor is offline
Old 09-24-2012, 09:02 AM
  #3163
Carranza76's Avatar
Will e-mail work? What proof do you need if any at all that you own one?
Old 09-24-2012, 09:06 AM
  #3164
Grandturk's Avatar
Ryan - just spoke to customer support and they are sending out the new cups to me. Thanks.
Question - are you still modding the new cups?
Grandturk is offline
Old 09-24-2012, 09:09 AM
  #3165
Casper's Avatar
Trader Rating: 34 (100%+)
No newball cups are already "cut down" is my understanding.
Casper is offline
