TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 09-20-2012, 08:14 AM
  #3046
will g's Avatar
Trader Rating: 132 (100%+)
Originally Posted by easye View Post
Im running dunfords set up and really like it. Might want to give that a try.
i dont have that set up ... do you have so can check it out
will g is offline
Old 09-20-2012, 08:19 AM
  #3047
easye's Avatar
Its on the first page of this forum at the bottom of Scotts listing post with the other setups
easye is offline
Old 09-20-2012, 08:21 AM
  #3048
will g's Avatar
Thank you
will g is offline
Old 09-20-2012, 08:28 AM
  #3049
Carranza76's Avatar
Scott you may want to add this to the front page.
Pretty cool that have these now.
http://www.horizonhobby.com/products...2sct-TLR232000
Carranza76 is offline
Old 09-20-2012, 08:38 AM
  #3050
I heard you won last night....good job....truck looks better every week!
Jason Snyder is offline
Old 09-20-2012, 08:41 AM
  #3051
SRC_DRIVER's Avatar
Trader Rating: 64 (100%+)
Originally Posted by JEDWARDS View Post
Joey,
That was fun but 15 trucks separated by so much time was a bit of a mess in the main lol.. I still haven't been able to figure out why my truck didn't take off at the start of the main.
SRC_DRIVER is offline
Old 09-20-2012, 10:46 AM
  #3052
ScottKelly911's Avatar
Done, thanks for the heads up!
ScottKelly911 is offline
Old 09-20-2012, 11:08 AM
  #3053
vito's Avatar
some one tell me what the 1 mm under the gear box dose thanks
vito is offline
Old 09-20-2012, 11:24 AM
  #3054
Grandturk's Avatar
Read the first page. It has links to the TLR blog about it.
Grandturk is offline
Old 09-20-2012, 11:33 AM
  #3055
vito's Avatar
thanks found it
vito is offline
Old 09-20-2012, 12:25 PM
  #3056
Casper's Avatar
Trader Rating: 34 (100%+)
Reedy Truck race coming up in a couple weeks (Oct 6-7)at Hot Rod Hobbies. Anyone on here running there 22-SCT's at this race!
Casper is offline
Old 09-20-2012, 02:06 PM
  #3057
easye's Avatar
Ok guy here is a cheaper alliterative to captured rod ends. The ball cups part #acs91051 ($4.99) and ball studs part#acs91047($9.00) the ball cups are offset and clears the rack and spindles with no bind and you use the tlr stock turn buckles and there is enuf to do 2 trucks if your only doing the steering.
easye is offline
Old 09-20-2012, 02:20 PM
  #3058
ach86's Avatar
Trader Rating: 45 (100%+)
Is anyone else running the mid motor currently? I have mine set up this way. Do have some weight on the rear for outdoors, but looking for this thing to be hooked up for indoor season. Truck seems to handle, fly, and jump much better than any other. I can "almost" power it like a 4WD SC. Just curious to see what others had done to make up some traction outdoors.
ach86 is offline
Old 09-20-2012, 03:01 PM
  #3059
Grandturk's Avatar
Honestly my truck is hooked with near stock setup. I pull the trigger and it just puts the power down - 8.5 boosted. I want to drop in a 6.5.
Sorry - mine is rear motor.
Old 09-20-2012, 03:17 PM
  #3060
elecRC23's Avatar
i have mine in a mid motor setup and am probably gonna put some weight in the back. i run on a high traction indoor clay track so i don't need too much.
elecRC23 is offline
