TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 09-15-2012, 04:12 PM
  #2881
rimracker's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Gas Rat Racin
How many shims are you using?
I was using 2mm but I went to 0 and it is much better. Upon closer inspection with a light the servo arm was to close to the rack while going left. Rookie mistake, live and learn...
rimracker is offline
Old 09-15-2012, 05:20 PM
  #2882
Grandturk's Avatar
Yes Vito - you got the one bad body.
Grandturk is offline
Old 09-15-2012, 05:22 PM
  #2883
vito's Avatar
lol it look funny the wheel are to the front not center in the cut outs.
vito is offline
Old 09-15-2012, 05:39 PM
  #2884
Cloaked's Avatar
Trader Rating: 15 (100%+)
Trying to decide what Front Tyres to run.
Currently have a set of AKA Grid Irons in Soft, and trying to decide whether I should run AKA Rebars in SuperSoft on the Rear or another set of Grid Irons in SuperSoft.
I run on an Outdoor track that is a mixture of hard pack dirt/clay with a loose very fine dust on top and it changes from High bite on the racing line after its been swept to very loose if its not swept.
Cloaked is offline
Old 09-15-2012, 05:43 PM
  #2885
F N CUDA's Avatar
Trader Rating: 34 (100%+)
Copy the quick guys at your local track, save a few bucks instead of guessing.
F N CUDA is offline
Old 09-15-2012, 05:46 PM
  #2886
vito's Avatar
i see i have rc 10 tires and wheels lol
vito is offline
Old 09-15-2012, 05:53 PM
  #2887
Cloaked's Avatar
All over the Shop from M3 Snipers , Green Double Dees, Soft Grid Irons.
There is no consistency.
Guess I just need to find a Tyre I like...
Cloaked is offline
Old 09-15-2012, 06:21 PM
  #2888
F N CUDA's Avatar
Sounds like a lot of tires work or a lot of guys are still searchin there?
List your type of surface and I'm sure a TLR guy can send you a recommendation that will be really close.
F N CUDA is offline
Old 09-15-2012, 07:15 PM
  #2889
theproffesor's Avatar
Trader Rating: 66 (100%+)
Originally Posted by will g
Nice rig ... what body is that Flowtek ... also if you could post pic of the back of the body wanna see the mounting holes ... thanks Will G
No its the TLR body that came in the kit. I just used cut out the pre made dots that were on the body for mid motor.
Attached Thumbnails TLR 22SCT Thread (Check First Page for FAQ & INFO)-sam_1911.jpg
theproffesor is offline
Old 09-15-2012, 07:23 PM
  #2890
vito's Avatar
where the dots on the body right? the body i have was off some in mid motor.
vito is offline
Old 09-15-2012, 07:44 PM
  #2891
Cloaked's Avatar
Cloaked is offline
Old 09-15-2012, 11:15 PM
  #2892
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by iTz Nicholas72
You mean up makes it less aggressive? Typo?
Yes, I typed it wrong, my bad. Raisin the spindle will make it LESS aggressive.
Frank Root is offline
Old 09-16-2012, 12:02 AM
  #2893
KalEl63's Avatar
Originally Posted by Frank Root
When you move the block down, it tends to make the car more aggressive. When you move it up, more aggressive. When you adjust spindle height, you should also adjust your shock limiting accordingly.
So if you have 3mm in shock limiters and you move the block down 1mm you should take 1mm out of the shocks?
Why is this?
Secondly how do you know what shock limiters to put in your shocks too?
(sorry noob questions)
KalEl63 is offline
Old 09-16-2012, 05:52 AM
  #2894
goehm's Avatar
Trader Rating: 45 (100%+)
Originally Posted by vito
body mount dots dot line up at all just the fronts. there off in the rear in mid motor and rear set ups . is my body mess up?
Just set the body on the truck how you like it, mark where the body posts hit the body, and then put holes on those marks.
goehm is offline
Old 09-16-2012, 07:18 AM
  #2895
will g's Avatar
Trader Rating: 132 (100%+)
Thanks it looked like the Flotek ... i ran my body first day and already has a crack at the back from those nice bumper and run drivers LOL .. anyone else run different body yet other than one that came in kit ?
will g is offline
