TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 09-07-2012, 06:33 AM
  #2476
Grandturk's Avatar
Originally Posted by mavrick0 View Post
Question for the TLR guys. With the support kit what's the point of the 60mm turnbuckle when the 22sct only uses the 65mm and 70mm one's?
So you can run shorter links if necessary - say if you use the inside positions on the rear camber link - you may have trouble getting the stock link short enough without modifying the ball ends.
The better question is why Do they only give you 1 link - obviously 1 link of each size is only good to replace a lost link. That's like only giving you one spring.
Grandturk is offline
Old 09-07-2012, 06:40 AM
  #2477
weavty1's Avatar
Yeah, and with the support kit, they give you one (1) spare spring of each flavor... lol, who loses just one spring? haha
weavty1 is offline
Old 09-07-2012, 06:49 AM
  #2478
Arigato's Avatar
Not true...You get 2 pairs for the front and rear that are one rate softer and one rate stiffer than the springs that come with the truck.
Arigato is offline
Old 09-07-2012, 06:50 AM
  #2479
Grandturk's Avatar
No they give you 4 pairs of springs - front green & black and rear pink and white. I already have green and pink from the 22T and white and black from buying separately. And anyway I run the rear buggy springs.
Old 09-07-2012, 07:21 AM
  #2480
weavty1's Avatar
Oh wow, I could've sworn I saw only individual springs of all colors.. My bad
weavty1 is offline
Old 09-07-2012, 07:30 AM
  #2481
Grandturk's Avatar
That's another $1 for the "Sorry" jar
Old 09-07-2012, 07:45 AM
  #2482
elecRC23's Avatar
So this truck doesnt come with a bag "F" i think it was, that has extra pistions and springs for tuning purposes?
elecRC23 is offline
Old 09-07-2012, 07:47 AM
  #2483
Grandturk's Avatar
It does come with the piston but no extra springs. I thought that was missing as well but it's in there.
Old 09-07-2012, 08:53 AM
  #2484
Trader Rating: 18 (100%+)
I did all the break in and everything seems normal. I guess I will try and tighten the slipper some more.... Everything is quiet. It just doesn't feel like it is grabbing. I have to get speed, no torque.
bot5024 is offline
Old 09-07-2012, 09:06 AM
  #2485
Briguy's Avatar
Trader Rating: 125 (100%+)
If your slipper is slipping that much you should be able to hear it slipping . I usually set my slippers to slip 1-2 feet on the track surface . If your diff is slipping you will hear a barking sound , if it is your diff tighten it up right away or you will melt the diff gear .
Briguy is offline
Old 09-07-2012, 09:18 AM
  #2486
Carranza76's Avatar
newbie questions but how can you tell your slipper is slipping 1 to 2 ft before it grabs? I have tried to see it myself just not sure what I am looking for or listening for.
Carranza76 is offline
Old 09-07-2012, 09:20 AM
  #2487
Carranza76's Avatar
Mines ready to go:
Just need to paint the body. I couldn't get my Proline Chevy Flotek from my XXX SCT to fit.
I got my HK RX's in yesterday and put one in my 22 buggy to replace my SR3100 and i get a LOT more range out of it and it seems so much smoother!
I am saving my other for the 22SCT.
Old 09-07-2012, 09:50 AM
  #2488
Follow up to bad diff thrust washer. I had the inner thrust washer shatter on my diff. Yesterday I called customer service. They are sending me a complete diff service kit because he didn't show the thrust assembly in stock.
TLR CUSTOMER SERVICE ROCKS.
losi b is offline
Old 09-07-2012, 01:24 PM
  #2489
Trader Rating: 28 (100%+)
anyone run with the gear diff yet? thinking of starting with 3k oil but figured i'd see if anyone has tried it yet
bobf24 is offline
Old 09-07-2012, 01:30 PM
  #2490
Guch's Avatar
Default Gear diff
I thnk the gear diff is a great option for those who like to race more than wrench. I've seen somewhere in the posts somebody put 5,000 in for starters. I'm not a good enough driver to tell the difference. Will propably install one after my ball diff is worn out. Alot of talk over in the 22 buggy section about gear diffs "diffing out". You should check it out.
Guch is offline
