TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 09-03-2012, 09:35 AM
  #2206
Trader Rating: 19 (100%+)
I've got a 22B and run "shorty" packs. Considering getting a 22SCT but don't want to have to get another pair of batteries. Running some added weight in combination with the "Shorty" pack would be same as running a standard length pack right? Think I could just add some lead weights behind or in front of the battery to make up for lost weight.
iTz Nicholas72 is offline
Old 09-03-2012, 09:36 AM
  #2207
vr6cj's Avatar
Trader Rating: 124 (100%+)
Originally Posted by AlienModified View Post
Gotta say I love the truck, I just need to look for a better tire for muddy conditions.
[/IMG]
Goose bumps tire have always worked well for what you described for me.
Originally Posted by RC-1 View Post
Question for you guys? Do the machined pockets in the chassis look like a 10 tear old machined them on yours?
yeah, they decussed this a bunch of pages back. even pics.
vr6cj is offline
Old 09-03-2012, 12:04 PM
  #2208
Miller2's Avatar
Default Tlr hi flow body. Tlr8060
Anyone try this body on a sc10
Miller2 is offline
Old 09-03-2012, 12:09 PM
  #2209
Ray Kindstrom's Avatar
Trader Rating: 151 (100%+)
Hey Miller....why don't you try "this body" on "this truck"? You can drive mine next time I see you.
Ray Kindstrom is offline
Old 09-03-2012, 12:19 PM
  #2210
theproffesor's Avatar
Trader Rating: 63 (100%+)
So are the o-ring that go in the pre-load collars availabel seperate. Mine got torn. I am using the ones form my 22T for the time being, but I need to replace them and dont want to buy the collars if I dont have to.
theproffesor is offline
Old 09-03-2012, 12:20 PM
  #2211
Anyone running a 10.5 motor yet? I'm trying to figure out gearing for a 10.5 tekin redline. I was running 84/23 as per Casper on my XXX-SCT but I know this is a little heavier.
xlayedoutx is offline
Old 09-03-2012, 12:46 PM
  #2212
GNS Racing 86's Avatar
running a fantom 10.5 no timing indoor small track 21 -86 and its perfect, 130 on the motor after a full battery pack and like 90 on the esc
GNS Racing 86 is offline
Old 09-03-2012, 01:41 PM
  #2213
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
ball cup performance:
got to run my truck for the first time yesterday. put about 5 or 6 packs through it. naturally the truck took some decent hits. i had a ball cup pop off once. it happened when the truck basically landed on one of the front tires off a jump (so i didn't hit a pipe or anything). not bad at all. two other buddies put 4 to 5 packs through their trucks and they never popped one off.
so basically i don't think it's an issue. certainly not a big one.
the truck handled great on our loose, hardpack outdoor track. when i went to the higher grip indoor track, the truck definitely felt a bit lazy. i raised the ride height and that definitely helped but the suspension needs to be stiffened up to run a higher grip track.
RC*PHREAK is offline
Old 09-03-2012, 03:14 PM
  #2214
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
Any bearing shop should have them. just take one in for them to size up
ozzy-crawl is offline
Old 09-03-2012, 03:32 PM
  #2215
Witnessed a guys 22sct at track with only trimmed cups pop the steering rack balls coming down from biggest jump on track. Swapped to smaller xxx-sct rods,balls, and cups and still did it. Ended up with .030 washer under ball stud and i think he might of filed a little bit.Finished 5min qual and 8min main w/o a popped cup and posted lowest lap time ever on track with short course truck, didnt win but pretty impressive for his first time out with truck. Its a shame that such a nice truck can get bashed, seems it shouldnt be in those hands in the first place, they may want to stick with a RTR so they can blame someone else since there's no way they could've made a mistake assembling and setup ;-) You never get the complete story, if you did you'd have an obvious answer .
NOS1K is offline
Old 09-03-2012, 03:40 PM
  #2216
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Yes, you can run extra weight to off-set the shorty packs, but if you are running stock, Travis Brock's setup is for a shorty pack, so I might suggest trying that.
Frank Root is offline
Old 09-03-2012, 04:28 PM
  #2217
goehm's Avatar
Trader Rating: 45 (100%+)
Here are the gearing recommendations from the manual:
I'd start there and adjust accordingly depending on heat and performance.
goehm is offline
Old 09-03-2012, 04:29 PM
  #2218
vito's Avatar
is the gearing the same in the trans as all 22 kits
vito is offline
Old 09-03-2012, 04:31 PM
  #2219
goehm's Avatar
Actually I think you're in a great position if you already have shorties - run them if you got 'em. You can then add the weight wherever needed most.
Coming in lighter than (ROAR) regs is always nice because you can choose where you add weight. When you're heavier your choices become more limited.
goehm is offline
Old 09-03-2012, 04:35 PM
  #2220
goehm's Avatar
They're all 2.43:1 internal gear ratio for standard (rear) configuration. Though, I don't know if you convert to a mid-motor if that changes the ratio (since you add another idler gear).
goehm is offline
