TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 09-01-2012, 07:35 AM
  #2101
Finished my truck yesterday. Not so happy with it. Turning circle does not seem very tight, also broke my diff bolt so now everythig is on hold untill I get a new bolt.
sgtlt is offline
Old 09-01-2012, 08:10 AM
  #2102
RShockley's Avatar
Originally Posted by Frank Root View Post
The front pin brace goes behind the arms, between the arm and the pivot. If assembled correctly, there should be no fit issues.
I would start with this list from the Team Losi Racing Blog:
http://losiracing.blogspot.com/2012/...d-i-start.html
Keep in mind a few parts for the 22SCT maybe be a little different, like the hexes. We'll try to get a 22SCT specific blog entry done next week.
Motor: Orion VST Pro 6.5T is what I run, but you may want a spec motor? Not sure what you want to race.
ESC: Orion R10 Pro, regardless of classes. ORI65102
Thank!
Frank
Frank, what settings do you have on your Orion esc. I'm running an Orion r10 pro and VST 6.5 with 18/87 for gearing.
RShockley is offline
Old 09-01-2012, 08:44 AM
  #2103
sylv456's Avatar
Originally Posted by KalEl63 View Post
Awesome news on the ball cups, is this the same for international customers?
So, how will we poor europeans get the new part?
sylv456 is offline
Old 09-01-2012, 09:00 AM
  #2104
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Sorry to hear your experience has not started off well. If you call HH PS or CS on Tuesday, they'll get a new diff screw out to you. As for the turning circle, are you getting full throw in both directions, to where the spindle bottoms out on the caster block? The 22 platform has the most steering throw of any of the cars we have measured, so there might just be something afoul in the radio setting.
I am running 16/86 for gearing, so you are up a couple of teeth from where I would suggest to start. I run 10% drag brake, 5 DRRS, Initial Brake = Drag Brake, 75% brake force (85% EPA/Travel, but this is really PP), Neutral Range @ 9, all with no turbo or boost. I also turn the timing of the most negative (clockwise) 1 line from the neutral tab.
Frank Root is offline
Old 09-01-2012, 09:14 AM
  #2105
B00t13g's Avatar
Frank, any chance you could touch on what I asked Casper?
B00t13g is offline
Old 09-01-2012, 09:18 AM
  #2106
Bobby Z's Avatar
My kit came with two rear motor shock towers. Planned to build the truck mid motor. I will call Horizon on Tuesday.
Bobby Z is offline
Old 09-01-2012, 09:30 AM
  #2107
vito's Avatar
thank you guys got the kit on the a main sale for 245 shipped so happy thank you so much time to get my work space all set up now
vito is offline
Old 09-01-2012, 09:53 AM
  #2108
Thanks for the reply Frank. I will call on Tuesday about the screw,and check my travel.
sgtlt is offline
Old 09-01-2012, 12:19 PM
  #2109
TLRacing
Frank Root's Avatar
What did you ask Casper?
Old 09-01-2012, 12:50 PM
  #2110
mxracer458's Avatar
Trader Rating: 47 (100%+)
Saw a couple of these run last night,I was really surprised how smooth they were and they were so quite you wouldnt even know they were running.
mxracer458 is offline
Old 09-01-2012, 01:10 PM
  #2111
Trader Rating: 38 (100%+)
[QUOTE=Frank Root;11160945]Sorry to hear your experience has not started off well. If you call HH PS or CS on Tuesday, they'll get a new diff screw out to you. As for the turning circle, are you getting full throw in both directions, to where the spindle bottoms out on the caster block? The 22 platform has the most steering throw of any of the cars we have measured, so there might just be something afoul in the radio setting.
I had one brake as well. Just called the LHS and ordered another one and had it in a couple days. I don't think it's a problem with the screw I think I got carried away or the plastic diff nut might have bound up. It's the only thread I didn't lube up.
hobbyten is offline
Old 09-01-2012, 01:11 PM
  #2112
B00t13g's Avatar
Casper, in your opinion, how would you change dunfords setup to run on a low- medium traction track? I'm having an issues with my car over rotating off throttle. Currently running the stock blue front springs with the truck rear whites. 55 pistons f/r associated 30 front 27.5 rear. I realized I was running 2/b on the rear camber link instead of 1-d, I changed it, but I have not had a chance to run it. Also on his setup, when he refers to 1 or 2.5 spacers does he mean 1mm and 2.5mm respectively? I have not added the weight to the rear either :/
I have run it at 1-b now and it definitely seems better. I also put the front link to the 1 hole which has helped, but I would like just a touch more traction. Do you think adding weight would be my best solution?
B00t13g is offline
Old 09-01-2012, 01:14 PM
  #2113
Trader Rating: 60 (100%+)
First run on truck today went pretty well except for ball cups keep popping off, but I haven't dremeled the steering rack yet. Anyways the truck did seem a little bouncy I am running dunford's setup on indoor hard packed track was considering going to 35 weight shock oil front and rear to see if that helps settle the truck any thoughts.
motobigalow is offline
Old 09-01-2012, 01:42 PM
  #2114
trickedout's Avatar
Trader Rating: 31 (100%+)
you mean $345 shipped???
trickedout is offline
Old 09-01-2012, 02:11 PM
  #2115
AndrewTom's Avatar
i was thinking the same, $245 would be like 30% off msrp!
AndrewTom is offline
