TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 08-29-2012, 07:11 PM
  #1876
KalEl63's Avatar
That spring chart is awesome weavty1. I have been working on a 22 family parts chart of every part in the 22 family and what fits what.
Haven’t finished yet but getting close.
KalEl63 is offline
Old 08-29-2012, 09:43 PM
  #1877
B00t13g's Avatar
How is everyone getting 25 degrees of front kick? As in what parts?
B00t13g is offline
Old 08-29-2012, 09:49 PM
  #1878
AndrewTom's Avatar
I think you can use the kick shims or pivot block from the 22 buggy or the 22T
AndrewTom is offline
Old 08-29-2012, 09:52 PM
  #1879
easye's Avatar
tlr 1051
easye is offline
Old 08-29-2012, 09:53 PM
  #1880
Default Ball Cup Popping Off Solution!!!! Solved!!!!
Guys,
This has been going back and forth. Some say it is a problem some say no. This may all depend on the track you are running on. I ran at Dirtburners on Tuesday night in Detroit. This is a hard clay fast tight track. In practice before doing any of the mods I had to go searching for the complete turn buckle link because it popped of both sides. This was caused by clipping the inside of the tube in a high speed sweeper. Yes I should have not clipped the tube but I did. The truck did not flip over and I continued on and realized I had no steering. So I went to the pits and did the mod. This did help. It stopped the turn buckle link from popping off the rack but it did come off a couple times on the wheel side just like on the 22T. I finished second in the SCT mod A-main and was just very careful not to hit anything. So Wed I spend 6 hrs at the track testing and did have issues with the outside popping off under light impact. Below are the details and pictures. This allows complete steering motion with no binding at all. Yes it is exessive but this is all I could find after looking through all the parts in the hobby shop. I think with would be a great solution in a smaller scale. Another solution maybe just making the ball studs bigger in diameter. More surface area gives better strength.
Hot Bodies Parts
HB67206
HBC8100
2 SCTE Links from 4x4
4 Losi screws to go through the balls
Attached Thumbnails TLR 22SCT Thread (Check First Page for FAQ & INFO)-imag0408.jpg
Losi 1972 is offline
Old 08-29-2012, 10:08 PM
  #1881
B00t13g's Avatar
Thanks guys, I ordered all of the stuff to do the kick adjustment, 5 degree caster as well as the rear threaded hinge pins/ front king pins, avid front truck springs and aluminum ball cups. Should be a fun saturday race. Girlfriend is out of town!
B00t13g is offline
Old 08-29-2012, 10:09 PM
  #1882
AndrewTom's Avatar
Losi 1972-
what links did you use from the SCTE? the steering, front camber, or rear camber?
Old 08-29-2012, 10:33 PM
  #1883
Originally Posted by AndrewTom View Post
Losi 1972-
I used the 2 shorter ones. After setting the toe I think you can get away with using the longer ones also. I did not check this. The SCTE has 2 short links and 4 longer links.
Old 08-29-2012, 11:03 PM
  #1884
Oasis's Avatar
Trader Rating: 38 (100%+)
Originally Posted by easye View Post
tlr 1051
I used TLR 1049..Brass kick angle shim 25 deg :22
Oasis is offline
Old 08-29-2012, 11:05 PM
  #1885
elecRC23's Avatar
So what exactly did you do to it?
elecRC23 is offline
Old 08-29-2012, 11:17 PM
  #1886
easye's Avatar
What are you refuring to?
easye is offline
Old 08-30-2012, 12:58 AM
  #1887
B00t13g's Avatar
Originally Posted by Oasis View Post
I ran one last night..well..for 2 heats, put the ball diff in and went almost 2 seconds a lap faster, I was running 7K on a hooked up small indoor track, the gear diff is for a 22B and stock is 5K on the fluid..the gear diff was ok but the ball diff was much easier to drive for sure..
FYI stock is 1k. Thanks for the help man, I'll give it a try tomorrow. The kit drove far from bad today, but I didn't even get two packs with it and all I've been driving is 1/10 th sedan and 1/8 nitro buggy. I can already tell it is leaps and bounds better than my old xxx sct, boy am I glad that thing is gone.
B00t13g is offline
Old 08-30-2012, 02:36 AM
  #1888
ScottKelly911's Avatar
Made it smaller to fit the page better, goin on the front page now. Thanks again Weavty1
Attached Thumbnails TLR 22SCT Thread (Check First Page for FAQ & INFO)-picture-63.png
ScottKelly911 is offline
Old 08-30-2012, 03:41 AM
  #1889
Beef_NZ's Avatar
Can any body please tell me if these have been shipped over seas? Im in New Zealand and really want to get my hands on one.
Beef_NZ is offline
Old 08-30-2012, 03:47 AM
  #1890
juzza99's Avatar
Shops in Australia have them, I'm picking 1 up tomorrow.
juzza99 is offline
