TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 08-29-2012, 06:10 AM
  #1831
Gas Rat Racin's Avatar
Trader Rating: 37 (100%+)
Originally Posted by hacker07 View Post
Sorry for the confusion, I blew out, I was referring to both. If running without, I would consider buggy yellow springs on the rear.
So without sway bars I need yellow springs?? I already ordered the whites
Gas Rat Racin is offline
Old 08-29-2012, 07:32 AM
  #1832
B00t13g's Avatar
Where is everyone measuring their ride height? 29mm is higher than I set my 1/8th scale.
B00t13g is offline
Old 08-29-2012, 07:49 AM
  #1833
celt's Avatar
Originally Posted by Oasis View Post
Not sure just what you guys are hitting to pop the ball cups off but I had no problems racing tonight..and the other 3 SCT22's had no problems either..all I can say is WOW..this truck is bad a**.. I'm done with 4x4 SC..this was way more fun! Big thanks to John Shultz for the help at the track tonight..as always you rock!
I'm wondering if this explanation isn't part of the issue some are having, as I've had this issue on a number of totally unrelated (different mfg's) cars
The links and cups are really, really tight to adjust when new. So tight in fact, that they simply pop off when doing final adjustment. Some just get them to an acceptable length and pop them on.
If you do the latter, and you can't roll the steering links between your finger and feel full range movement, both fore and aft, when you compress the suspension violently, the link and cup are so tight, that they have no choice but to pop off.
I always use a little Losi green lube on the links and cups when new. It makes them easy to adjust immediately. I also make sure that I get full range, forward to back rotation of the cup movement on the ball stud.
As I look at my compressed suspension, the cups are fully clearing all obstacles at both ends. As a matter of fact, I can still rotate the cup/link a pinch while fully compressed (it's close). The only way for that cup to pop off is if I break an arm or shock tower - the cups coming off at that point anyway.
This make sense to anyone? I'm not suggesting anyone is doing anything wrong, I've made this same oversight. It happened to me once, I make sure I have free rotation of the cup/link pair and it's not happened to me since.
A hard, hard, crash? Sure...the cups coming off - that doesn't count.
celt is offline
Old 08-29-2012, 09:07 AM
  #1834
Grandturk's Avatar
Originally Posted by celt View Post
The links and cups are really, really tight to adjust when new. So tight in fact, that they simply pop off when doing final adjustment. Some just get them to an acceptable length and pop them on..
So I worked on my ball ends quite a bit last night. Never really had to do this before.
First, I pulled all the ball ends off the links and reamed out the very end of the link, first with a body reamer and the with an exacto. Basically opening up the hole that the turnbuckle threads into. This allows for extra clearance when adjusting the turnbuckle all the way in.
Second, I worked each ball cup in and out on the turnbuckle to break in the threads. I used Chapstick as lube and did all 10 ball cups in and out about 5-6 times if not more. The idea here is to make them easier to adjust so they don't pop off.
End result is they stay on better while adjusting.
Grandturk is offline
Old 08-29-2012, 09:13 AM
  #1835
Grandturk's Avatar
Anybody notice how little clearance there is between the trailing spindle and the front suspension arm. If I add in any more droop it will definately rub. The spindle is centered as per Ryan's last setup sheet.
Old 08-29-2012, 09:19 AM
  #1836
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by easye View Post
Hopefully before Trackside specktrum race at the end of october. Other wise setup sheets posted are useless. Can you post sizes of the bars by the color.
White = 1.0mm
Yellow = 1.2mm
Pink = 1.5mm
Originally Posted by Fabulous View Post
Everyone having issues with the ball cups popping off I have a fix for you.
http://www.amainhobbies.com/product_...nd-Servo-Saver
Since removing the servo saver from the steering rack from the old design on the xxx platform, this has been a known problem from day one with the steering rack on the new 22 platform. Not as bad with the 22 buggy since it has smaller lighter front tires. It's been an issue with the 22T and now the 22SCT. This is nothing new to TLR they just havent come up with a solution.
The lack of a servo saver is not the issue.
Originally Posted by xlayedoutx View Post
Quick question as I just picked up mine today but which one of these hexs would I need in order to run SCTE wheels?
http://www.horizonhobby.com/webapp/w...pe=productgrid
Also would these work?
http://www.amainhobbies.com/product_...CT-to-TEN-SCTE
The kit hexes will work fine with Ten-SCTE wheels, no other hexes are required.
Yes, it really has to do with the bone and arm angles based on the diameter of the tire. Since SC tires and the same diameter as 1/8th (more or less), then the ride height is in the same range as well.
Frank Root is offline
Old 08-29-2012, 09:32 AM
  #1837
B00t13g's Avatar
So where do I measure it. Lol
B00t13g is offline
Old 08-29-2012, 09:41 AM
  #1838
Fabulous's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Brian L View Post
So this is why you are so fast. Did you you run our 22SCT last night and what set-up if you did?
Hey Brian, Pretty much stock setup with a few tweaks. 30wt oil in front shocks, 5 degree caster block, inner bottom rear shock, rest is stock setup.
Fabulous is offline
Old 08-29-2012, 09:43 AM
  #1839
Fabulous's Avatar
Originally Posted by F_ME View Post
Note to self....run serrated locking axle nuts expecially when running wheel dish covers.
Did the same thing and wheels still fell off. Don't use the wheel disc.
Fabulous is offline
Old 08-29-2012, 10:23 AM
  #1840
vito's Avatar
is there two set of wheels in the kit?
vito is offline
Old 08-29-2012, 10:30 AM
  #1841
Casper's Avatar
Trader Rating: 34 (100%+)
Yep. 8 total wheels (4 pair). They give you a full set (4) of fake bead locks as well as a full set (4) of wheel disks as well. (wheels are black, covers and rings are yellow).
Casper is offline
Old 08-29-2012, 10:32 AM
  #1842
vito's Avatar
thanks the rims are black with yellow rings
vito is offline
Old 08-29-2012, 10:36 AM
  #1843
weavty1's Avatar
Thumbs up
Originally Posted by RC*PHREAK View Post
front page request:
it would be nice to have all of the spring rates/colors (and TLR part numbers) available for the truck. this being my first 22, there seems to be a lot of options with buggy springs, truck springs, etc and people recommending either type.
Made this myself yesterday.. I have the Excel file as well, if anyone is interested.. PM me your email and I'll send it to ya.
weavty1 is offline
Old 08-29-2012, 10:44 AM
  #1844
GNS Racing 86's Avatar
the disc is probally spinning in the wheel. couple drops of ca glue on the outer edge of the disc and score the flange of the wheel nut with a cut off wheel should cure this. just a small amount of glue and you should still be able to pop them off if needed. the disc are cool.....
GNS Racing 86 is offline
Old 08-29-2012, 10:50 AM
  #1845
Yeah, because the discs spin freely on the wheels the use of serrated nuts is pretty much negated.
The discs need to be keyed to the rims somehow, either by glue or an unlikely redesign. That way the serrated nuts are "locked" to the discs which are "locked" to the wheels.
I wish they would just make one piece dish wheels, in yellow of course
tonyxcom is offline
