TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 08-28-2012, 09:00 AM
  #1726
AndrewTom's Avatar
Originally Posted by theproffesor View Post
I'll be running in a 17.5 boosted class, what would be a good starting pinion/spur. Tight in door meduim bite track.
depends on your system. i am running 22/84 in my XXX-SCT with a viper vtx10r and vst 17.5. i run about 32 to 38 degrees of boost depending on track conditions. the XXX-SCT (with the TLR kit or a CR transmission[ball diff]) has the same internal transmission as the 22 (2.43:1)
AndrewTom is offline
Old 08-28-2012, 09:10 AM
  #1727
easye's Avatar
losa6044 is a captured ball cup for the losi 8b and 8t kits. The hole for the turn buckle will need to be opened up a little to fit and need 4/40 bolts 3/8in long with 4/40 lock nuts to attach to the rack and the spindle.
easye is offline
Old 08-28-2012, 09:19 AM
  #1728
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
There are no captured rod ends I am aware of that will allow for full travel on the 22SCT.
Frank Root is offline
Old 08-28-2012, 09:29 AM
  #1729
Grandturk's Avatar
Might have to compromise. A little less travel might be OK if it prevents a DNF.
Grandturk is offline
Old 08-28-2012, 09:32 AM
  #1730
easye's Avatar
Well I havnt dont it to the sct yet. But have had good luck with it on my 22t.
Dont take me wrong but what ends have you tryied. I dont have to spend hours trying diffrent part to save from having a dnf?
easye is offline
Old 08-28-2012, 09:33 AM
  #1731
goehm's Avatar
Trader Rating: 45 (100%+)
Originally Posted by vito View Post
will rpm ball cups work for the fixs?
On my XXX-SCT truck I never had any problems. I was refreshing all my parts and opted to try out RPMs in pretty blue. I replaced all ends and the very next day I start losing ballcups. I would not recommend RPM.
goehm is offline
Old 08-28-2012, 09:35 AM
  #1732
AndrewTom's Avatar
i don't know about the rest of you, but i would definitely compromise a little bit of travel if it means finishing the race.
Old 08-28-2012, 09:37 AM
  #1733
Super Moderator
Kraig's Avatar
Trader Rating: 80 (100%+)
Has anyone thought or tried the Kyosho ballcups yet?
Kraig is offline
  #1734
AndrewTom's Avatar
i run all the stock captured rod ends on my XXX-SCT. i even swapped out the inner steering link ball cups when i put in the spring steel set. no issues.
Old 08-28-2012, 09:45 AM
  #1735
GNS Racing 86's Avatar
i also did this on my xxx sct. it worked good. i had a xxt that had some tappered (cone) shaped spacers that went under the captured flanged tie rod ball. this elimenated the binding, but changed the bump steer a little. but never poped a ball end again. i dont know if these use to be a losi part or not.. they were on the truck when i got it yrs ago. never tried to find any. maybe someone else knows about them...
GNS Racing 86 is offline
Old 08-28-2012, 10:16 AM
  #1736
It would be really fun building a kit for the first time in almost 10 years but I am glad I waited. With the new iPhone coming out and a payment coming up for the IRS, I can afford to wait for the first round of fixes and setups to come out. Keep working on it everyone!
tonyxcom is offline
Old 08-28-2012, 10:23 AM
  #1737
Midwest_Mudder's Avatar
ive used the losi "natural" ball cups on most of my stuff. they take awhile to get smooth but dont pop off for the most part.
Midwest_Mudder is offline
Old 08-28-2012, 10:37 AM
  #1738
vito's Avatar
i have my losi 22 buggy for sale at the lhs for 120 bucks with out motor and esc
vito is offline
Old 08-28-2012, 10:41 AM
  #1739
Trader Rating: 24 (100%+)
I use the lundsford ball cups on my 22 Truck and Buggy. They seem to hold on a lot harder then the stock losi cups.
chevmaro is offline
Old 08-28-2012, 10:50 AM
  #1740
easye's Avatar
Here is the best pics I can come up with my mod to help with the ball cups poping off.
Attached Thumbnails TLR 22SCT Thread (Check First Page for FAQ & INFO)-sct-mod3.jpg   TLR 22SCT Thread (Check First Page for FAQ & INFO)-sct-mod4.jpg   TLR 22SCT Thread (Check First Page for FAQ & INFO)-sct-mod-5.jpg   TLR 22SCT Thread (Check First Page for FAQ & INFO)-sct-mod2.jpg   TLR 22SCT Thread (Check First Page for FAQ & INFO)-22sct-mod.jpg
easye is offline
