TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 08-27-2012, 05:55 PM
  #1681
jkirkwood's Avatar
Originally Posted by hacker07 View Post
Going from 4 hole to 2 hole pistons on a couple of my vehicles has gven me grat results in the area of consistency. The car just feels more consistant and seems to land better as well.
Thanks, I will prepare some pistons to try then.
jkirkwood is offline
Old 08-27-2012, 06:04 PM
  #1682
Gas Rat Racin's Avatar
Trader Rating: 37 (100%+)
Where do you get a 1.5 and 1.6mm drill bits?
Ryan are you using a shorty pack with that setup?
Gas Rat Racin is offline
Old 08-27-2012, 06:07 PM
  #1683
jkirkwood's Avatar
If you don't have a metric drill bit set and only have numbered drill bits here's the closest sizes to the posted setup.
#53 = 1.5113mm
#52 = 1.6129mm
If you need a source for numbered drill bits I use these. They are not the greatest quality but for hobby use, they work very well.
http://www.harborfreight.com/60-piec...set-34627.html
Old 08-27-2012, 06:43 PM
  #1684
Got them at McMaster. I use the orion 5000 which is a long pack.
hacker07 is offline
Old 08-27-2012, 06:44 PM
  #1685
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
also, for the TLR1043 Front King Pin, Threaded, TiNitride (2): 22 do these go vertically through the caster block or horizontally through the arm? please forgive the n00b question...
RC*PHREAK is offline
Old 08-27-2012, 06:47 PM
  #1686
they go vertically through the caster block
hacker07 is offline
  #1687
Trader Rating: 52 (100%+)
Vertically through the caster block.
tonyd is offline
Old 08-27-2012, 06:51 PM
  #1688
RC*PHREAK's Avatar
thanks!
Old 08-27-2012, 07:13 PM
  #1689
Originally Posted by godofcable View Post
Actually it looks like piece of a handgun to me. I could be wrong though.
It's the lower receiver to an AR15.
tonyxcom is offline
Old 08-27-2012, 07:17 PM
  #1690
mynameis grumpy's Avatar
Which 2 vehicles have you done this on?
mynameis grumpy is offline
Old 08-27-2012, 07:42 PM
  #1691
AndrewTom's Avatar
Originally Posted by Oasis View Post
Viper VTX10R..it's a good speed controler..
i can agree with that!
advantages over the competition:
-ProGauge-trackside adjustments W/O PC-easily adjust all your settings, no blinking lights to watch or computer taking up your pit area!
-5 amp BEC- No rx caps needed, i run a savox 1258tg and sr300 rx with no issues whatsoever.
...to name a few!
AndrewTom is offline
Old 08-27-2012, 07:52 PM
  #1692
Is TLR5163 or TLR5166 the correct white spring for your setup? I see they both have 1.8 spring rates but one is buggy rear and the other is for the SCT.
Old 08-27-2012, 08:22 PM
  #1693
Its the second one TLR5166
hacker07 is offline
Old 08-27-2012, 08:30 PM
  #1694
easye's Avatar
Whats with the buggy springs over the truck?
easye is offline
Old 08-27-2012, 08:31 PM
  #1695
vito's Avatar
will it pull the front end up with a 5700 4 pole motor in mid motor if the slipper all the way tight
vito is offline
