TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 08-25-2012, 09:53 PM
  #1561
jmc23's Avatar
Default Set up
Originally Posted by hacker07 View Post
I know Toddie ran the kit setup and Keith ran the kit setup with the sway bars. I ran another setup but I would say Toddies truck looked the best of all of ours.
Thanks ryan
jmc23 is offline
Old 08-25-2012, 10:12 PM
  #1562
Originally Posted by RShockley View Post
Unfortunately I am working on Sunday. Morgan and I got some good testing done with iT after racing tonight. The box setup is a good start but we already have it way better with just a few small changes.
whats your setup for mikes?
nixhex32 is offline
Old 08-25-2012, 10:49 PM
  #1563
RShockley's Avatar
Even with the ball cup modification I'm still popping them off fairly easy. Any other ideas why.
RShockley is offline
Old 08-25-2012, 11:40 PM
  #1564
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Mototech View Post
Anybody know if a Spektrum S6040 requires an extension wire in rear motor? Thanks
Servo and reciever are typically right next to each other in these cars. It is the ESC that requires the extension if you put it on the tray in front of the rear tower. That wire will most likely be too short if you put the reciever up next to the servo.
Casper is offline
  #1565
Trader Rating: 2 (75%+)
Originally Posted by drtdino View Post
Just purchased a 22sct... Setting it up with an R10, a 8.5vst, barcodes, and savox 1258... I can't wait I haven't built a kit since I was a kid and that was 15 years ago, lol...
I hear you man... 27 now and my last kit was a XXX CR BK Hahahaha!!! Has been awhile huh? Going to be fun!!!
RCFreak32 is offline
Old 08-26-2012, 01:52 AM
  #1566
speed-e's Avatar
Trader Rating: 28 (100%+)
Originally Posted by motobigalow View Post
Putting a gear diff in my truck to try starting with 5000 diff fluid , thoughts?
A friend tried 5000 weight and the differential spun like it had bearing oil inside. I built mine with 30000 and it felt good. I'm thinking about trying 40000 or 50000 since I'm running mid-engine.
speed-e is offline
Old 08-26-2012, 04:41 AM
  #1567
Shoot me a pm with the changes please.
losi b is offline
Old 08-26-2012, 06:11 AM
  #1568
Trader Rating: 94 (100%+)
Default So good
Raced the truck for the first time yesterday at are local club race ran the stock setup was very impressed it handled great and carried alot of corner speed the track was outdoor mix of clay and dirt really dry and loose qualified 5th but took of in the main and was untouchable. Also I ran the shorty pack with two foams behind the battery I can wait to see what more this truck has in it I'll have to say out of the 22 series of rc's it's the best thanks Losi for stepping the game up Oh and also has plenty of steering
slyfinger1 is offline
Old 08-26-2012, 06:14 AM
  #1569
RShockley's Avatar
PM sent
Old 08-26-2012, 07:08 AM
  #1570
murky123's Avatar
that is pretty serious, becouse it will result in a DNF fairly easy
murky123 is offline
Old 08-26-2012, 09:31 AM
  #1571
vito's Avatar
ok some one from losi post is for you. i now see pics of the stock body with the holes not cut out. is there two body with the holes cut and one not cut. not in the kit in the kit theres just one i know.
vito is offline
Old 08-26-2012, 09:46 AM
  #1572
Wildrcracn's Avatar
Trader Rating: 41 (100%+)
Default 22Sct servo question
First off , hats off to losi
Great truck
Great instruction manual
Very very happy
Question to the pros on here, what servo are u guys running on the 22sct?
The servo I'm running is Align 610 which is just like a savox 1257, I believe that number is right.
Anyways the servo rubs on the link, and is too close for me , are u guys running a smaller servo , that is flater in the front ?
Thanks for the help
Ps I use no shims, also my tekin rs is glitching so now have to run a cap
Wildrcracn is offline
Old 08-26-2012, 10:17 AM
  #1573
Gas Rat Racin's Avatar
Trader Rating: 37 (100%+)
I'm glad to hear some of you had a good first outing with the truck, but I wasnt so lucky. The ball cups on the steering came off 3 times and the rear end was really loose. The track is a loose, bumpy, dusty, 1/8 outdoor. I put the kit setup in and did the tranny shim trick. Any help on how to get the rear end planted would be great!!
Gas Rat Racin is offline
Old 08-26-2012, 10:43 AM
  #1574
ScottKelly911's Avatar
Try throwing some weight over the transmission. One of the 7 gram weights in the option parts that use the factory hole. Also try laying the rear shocks down. Outside on the arms, second from the inside on the tower. If those dont fix it, then try a softer spring in the rear also.
ScottKelly911 is offline
Old 08-26-2012, 10:57 AM
  #1575
Casper's Avatar
You need to cut the wholes out. (I am assuming we are talking about the vents?)
You get to choose with this body. TLR will be offering a body with all the vents cut out but it is not scheduled to be released until nov at this time.
Casper is offline
