Do you guys do a "whip" over jumps?
I've been watching the nats in PA all day and couldn't help but notice how many people like to throw their cars sideways over jumps. Do you guys do this? Is it purely for style or is their really an increase in speed through the air? How do you do this? Sometimes I get lucky and pull one off, but normally when I race I concentrate on just making the jumps!
it also helps you set the car up for the on comming turn by shifting the weight. not very difficult to do but very difficult to do consistantly. And you have to have a pretty good set-up on your car. if the suspension is too stiff it will flip on landing, too soft and it absorbs the weight transfer and you get nothing.
Me no one im not a "pro driver " but do race in a pro truggy class at times not always . I have to much other things to worry about when jumping lol.
But ive noticed any guys do that at the tracks ive been to .
Its really a pro driver a "paid driver" kind of thing ive noticed watching videos.
Im not sure hows its possible with a rc car the only thing i can think of is that you have to turn the front wheels full lock a little before you land.
You're the only one I've seen mention "motocross" scrub in here. When I said whip or scrub all I was saying was hit the jump in a way you can scrub speed and stay lower and it is "mechanically physically" possible.
To answer your question yes I do "whip" the car when it is advantageous.
What we are doing is setting up for a corner after a jump. When you throw the car off the jump in the direction of the next corner, the car wants to roll to the opposite direction of the corner (which will result in the car rolling upon landing, as the car is already angled in the roll axis toward the outside of the corner). So to counteract this you have to steer the wheels the opposite direction of the corner in the air. This will "lean" the car into the corner upon landing. If any of you have ridden street motorcycles you have no doubt felt the gyroscopic effect used in counter steering. When you turn the bars slightly to the left the bike wants to lean right. Simple physics really. Same principle at work on our r/c cars. Really good drivers can also "catch" the car in the air if it begins to roll. To do this you need to steer into the direction of roll. In other words if the car is rolling to the right, steer right and it will cause the car to roll back left. It is not really that hard (if you're good), it just takes practice. Once you get it figured out you can really control how the car flies and lands.
As for Mr. you can't motocross style scrub. Obviously a 4 wheeled r/c car can't get the lean angle coming off of the jump, but the concept is exactly the same. You turn one direction coming off the jump (it is just way more exaggerated on a dirt bike) and then once in the air, crank the wheels (or wheel) in the opposite direction to use the gyroscopic forces to correct the angle. It just so happens that on a dirt bike you can lean the bike to counteract/redirect the rebound forces of the suspension, thus "keeping it low". Also in addition to being able to lean a dirt bike, you have this dynamic (moveable) weight (the rider), which comprises about 40% of the weight of the bike/rider combo. Being able to throw this weight around also has a big effect on the flight characteristics of the bike.
Go to youtube and search 775k50QWlTM The video is local hot shoe Austin Blair getting down on the new layout at Nor-cal. Pause the video at 0:44 and look at how cranked the front wheels are (in the direction of the turn). Then go to 0:45-0:46 and see how his wheels are cranked the complete opposite direction.
Trader Rating: 18 (100%+)
Muahahahaaaa.... I likey!! ^^^
I used to love doing this with my hotshot in 86'... 4wd makes it so much more.. haha..
The "whip" we do with cars is purely a directional control. Because the car can't be leaned over on the face of the jump the loft from the jump will be more or less the same.
I do like to emply a different scrub when I can make it work. I approach the jump at high speed and chop the throttle (or even brake on the face) to shorten the flight. It's hard to do on some jumps but when it works it's a great way to pass.
All correct but to make sure readers really understand the differece, the biggest cause/effect of the moto scrub is that the rider can effectively shrink the height of the jump by the amount that he can lean the bike over. Done correctly, it is breaking traction of both tires and laying the bike down in the face of the jump. It's known as the "Bubba scrub" but James Stewart by no means invented it, he just did it in such an exaggerated manner that he was able to seize a bigger advantage with the technique. Others had to learn to do it like him to keep on pace. You can find video of Bubba doing this where his wheels have left the ground 1-3ft before the top of the jump and the side of the bike is just clearing the lip. How he gathers the bike back after this "controlled crash" is the magic.
So doing a scrub with a RC car I do not see how that is possible. Yes you can whip and setup the car for what is after the jump.
http://www.youtube.com/watch?v=WYytyij1wII
Whips, please. I do backflips over the triple while leading the A.
Only time I make adjustments mid air are when I come off wrong or I need to work a different line to get around traffic. We do have a 90 degree step up on the current layout that I have to make corrections on 7 times out of 10 attempts, about 1/2 of those attempts will get me what I'm after, a couple more close enough, and I'll screw up a couple. A few layouts back, there was a jump that you would have to "whip" every lap if you wanted to get through the section quickly.
