Do you guys do a "whip" over jumps?
#61
Whipping your car has zero benefit unless you are correcting for a bad takeoff, or setting up for a corner after a jump, or exiting a corner and not squared up while hitting a jump. All good drivers can and do make throttle and wheel corrections over jumps. Those of them who do whips over jumps on straight parts of the track are just playing and hurting their lap times.
The only way to adjust the height attained from a jump is to be on throttle up the face to bind the suspension and not allow rebound. Plain and simple.
#62
+1. Chill out guys.
I visited a track that actually had two sections of pipe that were set purposely so you COULD jump them. They would use neon green spray chalk to identify jumpable pipes.
Usually a S turn section, that would be an S turn section with a few jumps for 1/10th scale, but was a straight with a few jumps over the S and pipes for the 1/8th scales. Really neat, and fun.
That gives me a good idea for our backyard track.
#63
#64
Well let me ask this, has anyone here ever run on a track with a 90 degree corner table? One of the current layouts I've run recently has 2 left handers in a row and doing a step on/step off line is unbelievably slow. In order to be fast I had to hit the lip on one side with my wheels turned full lock to the left and "whip" the back end in the air to land on the face of the downside of the first, go full speed into the next one where I would slide sideways right before the lip to "scrub" excessive speed and to stay low over the jump, "whip" it once again and land on the downside full wood so my stock t4 would clear the massive step up next with 5 feet of run up to it. An I happend to set the fast lap in qualifying... So anyone that says that you can't scrub doesn't know what they are talking about, and yes whipping the car over jumps can help if you do it right. Both just take practice
#65
Well let me ask this, has anyone here ever run on a track with a 90 degree corner table? One of the current layouts I've run recently has 2 left handers in a row and doing a step on/step off line is unbelievably slow. In order to be fast I had to hit the lip on one side with my wheels turned full lock to the left and "whip" the back end in the air to land in the face of the downside of the first, go full speed into the next one where I would slide sideways right before the lip to "scrub" excessive speed and to stay low over the jump, "whip" it once again and land on the downside full wood so my stock t4 would clear the massive step up next with 5 feet of run up to it. An I happend to set the fast lap in qualifying... So anyone that says that you can't scrub doesn't know what they are talking about, and yes whipping the car over jumps can help if you do it right. Both just take practice
#66
#70
#71
I hope everyone who watches this thread has seen this, if not here is Elliot Boots' huge whip during Q4 of the worlds.
enjoy:
enjoy:
+ YouTube Video | |
#72
enjoy:
enjoy:
+ YouTube Video | |
#73
Not a whip, that was a save. The car rolled because of the rough take off of the jump. Then he steered into it to corrected it. Same principal at work, and if you have quick enough reflexes to pull of saves like this you can whip if you want. But in this case he didn't whip it on purpose.
#75
He didn't do anything to save it, other than possibly hammering the throttle. The front wheels only turn right as the buggy is touching down. Basic physics saved him-- the gyroscopic action of the wheels righted the car in air. How do I know? I do it all the time, with absolutely no effort. He just got lucky that it pitched almost perfectly onto it's side. Any other attitude would have turned it into a cyclone.
