Do you guys do a "whip" over jumps?
#16
#18
I know Maifield once said it gives you more control. Once you throw the car in the air, you need to correct, so with fine adjustments the car is already ready to move like you want, but if its not, the car isn't going to adjust as predictably. Theoretically you wouldn't need to do this at all if you always jumps perfectly, but no one does. You can also jump lower if you get on the gas/brake at the right time so you spend less time in the air. Its all works if you can always get it right like pro's, but I don't know many that think nothing of blowing off a couple sets of tires for practice...
#19
#20
I do it occasionally,most of us sponsored drivers get accused of showing off when it really does benefit the car rather than how it looks.I do it every few or so laps if i need to correct myself but the the leaders in our pro classes do it almost every jump,every lap,and the land same spot everytime.Whipping is great if you have a technical track because your already prepared for the turn while people are still preparing to turn in while your already in the turn,If you whip correctly you can pull away from alot of people at the right times,sometimes thats what i have to do to get some breathing room in pro class.
#26
Its not showing off, you can see that when he lands after he does a whip that he can just hammer the throttle and take off, where as others that aren't whipping have to turn first which takes more time. The last few on the big jump look like more for show though I agree :P
#27
On my track,(vid in my signature) sometimes when the main line gets rough, in order to clear the big triple in the back you have to really rail the big berm and carry all your speed with the throttle on all the way on to the jump right at the exit of the berm, so usually you're still turning off the jump, in these cases it's pretty much necesarry. Also, the landing is right at the next turn, so you can correct it to set you right up. It ain't easy(for me), but when I get it good it feels badass.
#29
To the question or argument that you cannot scrub (or speed jump)an r/c car.
While practicing last night I challenged myself to see if this is truly possible. What I discovered is that IT IS possible. Two key factors lead to a successful "scrub". To accomplish this the track was dry and I was using a less than perfect front tire. I had to hit the jump on throttle and not "blip" it.
The best results were gaining throttle up to the jump face but not full tilt. Just easing on briskly and giving the steering a twitch on the jump face and then chopping the throttle once the front tires clear the top. It takes some practice. For me it was many many runs at it but once accomplished it was a matter of timing (of course).
#30
