E buggy gearing
I have a Rc8.2e with stock spur gear and a tekin rx8 with a tekin 1900kv motor, what would be a good pinion gear size for a large track
Originally Posted by Bryce808
(Post 10852947)
So I'd put a 17,18, and 19 in my pit box since the 1900 has a bit less RPM than a nitro engine. |
Delete please. Sorry.
Start with 18 for the 1900. If your motor gets to hot move up to 19.
Originally Posted by sunco1
(Post 11007793)
I know they can get hot from being undergeared but you almost need to run full throttle for a long time for that to be the case. |
Originally Posted by RatsacK
(Post 11008529)
How does that make sense? Wouldn't a motor get hot if it was overgeared? :confused:
I run a 2050 in mine and after a 10 minute main with an 18t my motor temps were around 165. Switched to a 19t and they dropped to 150 after mains. Esc remained the same temperature. Im just speaking from experience i've had with mine..
Hmmmm! 18 t 165 then switched to 19 t went to 150 ? Maybe it's the other way around bro. Over gearing will brink the temp up or it could be that your on the throttle thereby reducing temp..
These are 3 phase motors that the ESC has to fire the right phase at the right moment. If you're under geared the ESC may not be able to keep up and timing gets screw'd up. Just my theory, not sure if true, just seems like brushless setups have a hard enough job allready, undergeared has to suck.
I've seen similar things happen to VFD drives. But a motor geared proper will run cooler than 2 teeth low (in 1/8th scale). And 19t is not over geared at all. 1900=31,920 rpm Nitro engine is 35,000-40,000 rpm. RC8 nitro is geared with a 16t bell. So a 19 or 20t pinion may be the hot ticket. In my lighter 808E 20t is perfect. |
(Post 11011472)
I want one
| All times are GMT -7. It is currently 07:07 PM. |
