B4.1 wolds car.. poor mans set up
#31
right. Speed Passion designed it for hobbywing to make it. But they weren't supposed to release it on their own. That's why Speed Passion Reventon series is designed and made by Speed Passion. From what I understand Orion did basically the same thing with Hobbywing. but it's the newest version and time will tell if hobbywing screws Orion over too.
#34
Everyone is using foreign components because no one makes them here. We don't bring in ESCs from overseas and slap stickers on them.
#35
1) motor - so I found someone willing to sell a reedy sonic 7.5 for $45
2) ESC - You guys all convinced me to get the brushless hobbies 120 Amp ESC check .... is this fully compatible with the Reedy Sonic 7.5?
4) servo - Solar Servo http://www.hobbypartz.com/33p-solarservo-d771.html
3) battery - cant find the reedy wolfpack or shorty lipo used ... also since i might get a 7.5 should I get like a 35C instead of 25c?
4) Flysky Tx and Rx -$40
So all together ... $200 ... thank you everyone for your input
But again if you strongly believe one of the things Im getting is wrong/incompatible/or cheaply upgraded please let me know soon cuz I'll be buying these tomorrow night
#38
Shop around for a softer motor. 7.5 is far too much for anyone who is "less than pro". You'll have a better time with a 13.5.
#39
They use them because they are good but more importantly, they are paid to.
Get a Novak Havoc with a 10.5 motor and a GensAce 40c battery. All the power you will ever need, for just about any off road race. For a servo, the Spektrum 6010 is really good for the money. It's faster than the stats would lead you to believe.
If you had the exact same stuff as the Pros you would not go any faster than with the gear above with the skills you (all of us) have. Keep it simple and concentrate on having the best tires and keep your car in the best possible condition.
#40
#41
what if i got the 7.5 then dialed it down with a low dual rate?
#42
I think you will be happier with 13.5 as well. Your lap times will most likely be faster, and most race classes require that. Also buy a hobby king battery not a used one. Who knows how much life is left in a used battery.
#43
Dialing it down doesn't really give you the same performance. I know hobbypartz has some 13.5t motors for cheap, I think hobby king does as well.
Most of the guys selling higher turn motors are selling them because they went to 13.5t
#44
Personally, I don't have experience w/ Flysky radios but I've seen many racers who started out with it ended up with Airtronics/Futaba/ or KO. Feel/speed of the radio is everything, so if you're ok with how it feels then go for it.
Just from experience, I think you're better off with a decent radio from the start which will save you $$ in the long run.
#45
