my losi ten t brushless conversion project
#16
people are telling me that i should get a 6.5 stator since i want to run 4s lipo is that true yes or no?
#17
can i use the pinion gears from my sc10 4x4 on my ten t? i hope i can.
#18
Yes, it's true about the 6.5. Much better option.
As for pinions, if you use all SCTE stuff for the conversion, no, your pinions won't work. SCTE uses a mod 1 spur. The SC10 4x4 can use 48p or 32p. Most use 32p. If you want to use 32p, you can buy this spur: http://www.rc-monster.com/proddetail...rod=rcm10tspur you can use 32p pinions with that.
#20
well everything for my losi ten t conversion project will all be in next week.
#21
i just bought a novak hv 6.5 motor for my losi ten t.
#23
what motor did it have in it?
#25
i am putting a novak hv 6.5 in my losi ten t.
#26
You shouldn't be putting anything more than a 3s lipo with those higher kv 550 motors..
best choice would have been a tekin 1800-2000kv buggy motor to be honest.. if you wanted 4s lipo. Super overkill for the platform.. a 3s lipo with 2000-3000kv is great. Any higher kv should be kicked to a larger 2s lipo imo.
#28
i already bought the motor so it has to go in my ten t. i will be using a 4s esc too.
#29
i checked novaks website for the manufacturers specs and the novak hv 6.5 is a 4s lipo motor so i am all good to go.
#30
Gearing will be very limited.. and almost unusable on a race track. I'd suggest looking at a 3s config. many more gearing options from crazy to decent. PS any ESC capable of 4s can do just fine w/ 3s.
