help identifying losi parts
The wheels could be from either xx or xxx, the top pieces look like there from a tc3 or tc4 sedan.
Not knowing the history of Losi buggies, is the XX just the older model to the XXX, and the 4/cr afterwards designates 4wd vs 2wd?
It's weird that those random TC4 parts are in there, the only other car parts with the losi stuff are serpent impulse parts. Thanks guys.
ok. The wheels are a set, medium width fronts with a hex drive, and wide rears with crosspin drive. I have all 4, I just didn't take a picture. They're the same size tires as my zx-5s, so I'm assuming their from a 4wd buggy.
The 2wd XX and XXX front rims have a 12 point feature, like a socket wrench, to fit the axle hex.
The 2wd XX and XXX rear rims have different offsets. If I remember right XXX rims on a XX ends up having a narrower track.
Your wheels/tires are for a xxx-bk/cr. The fronts(skinnier ones)are barcode/taper pin type of tire. Good for high traction tracks. The rear look like barcodes. They are for the 2wd buggy. The one that has one laying down and other next to it is a taper pin. Hope that helps.
I posted from memory earlier but wasn't sure since I haven't wrenched on either for years so..... Some of the leftovers from the good old days.
in this pic the left row is 4wd fronts, middle is 2wd front, right side row is rears for either. Top row is XX middle row is XXX and the bottom row I don't remember but they are not losi, notice how similar they are to the ops pic but the ribs are thinner and placed at the hub a bit different.
After looking at the ops pic carefully they are Losi xxx fronts and 2or4wd rears.
Here is shitty pic of mine. and a pic of the outsides
And I haven't thought of posting this here but as long as we have any help identifying the unknown ones would be nice. Heres a pic of the outsides.
The unknown ones were bought at MnM around 91? and mounted on this car for my first ever run on a clay indoor track. mounted and walked right over to the belt sander and buzzed the tread off, crazy weekend was awesome.
put it right back on the shelf, anybody need a box of xxx tires?
