RC10 gt Throttle Linkage question? >
Old 02-13-2005, 01:25 PM
Trader Rating: 247 (100%+)
Default RC10 gt Throttle Linkage question?
Hi,
I was wondering if some one could help me with setting up a throttle linkage for a slide carb on a RC10 gt. Pics of the right way to do this would be great. Also what parts do I need, Servo arms ect.
Thanks, Brad
berwicknitro is online now
Old 03-14-2005, 08:25 PM
hate to say it but the best T-linkage is to use the one from losi I set my gt up with that with a slide carb and it works...way better than the ae linkage.....man that hurts
hot-dogg-man is offline
Old 03-14-2005, 11:42 PM
beetlebz's Avatar
which one is that hot-dogg?
i would certainly be interested in seeing how you did that. All i can think of would be a T-Maxx style setup.
beetlebz is offline
Old 03-15-2005, 06:43 AM
I will get you the part # have not seen the t-maxx set up the losi set works good because it doesn't have so many parts to fall off or to jam up
Old 03-18-2005, 08:59 AM
Don't know if it will work on a slide, but the Ofna linkage set is smooth and reliable for the GT.
rocknbil is offline
Old 03-18-2005, 01:28 PM
beetlebz's Avatar
hey rocknbil! i dont think ive seen you off the car action forums hehe
do you have a pic of the linkage?
beetlebz is offline
Old 03-18-2005, 03:29 PM
Heh. Well I try to stop by all of the forums as I find time.
Here you go, the linkage comes short of one rod, so plan on using your existing brake rod or buy an extra. You can get them on eBay or Tower for $6-$7. The best thing about them is the plastic slides and doesn't "hang up" on burrs on the rod, and gets rid of that wobbly throttle pivot.
The servo horns are aluminum (Trinity?) and don't come with the linkage kit.
Like I said, I don't know if they work for slide carbs.
rocknbil is offline
Old 03-19-2005, 02:39 AM
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
He's asking for a linkage on a slide carb...
your best bet is to get a longer rod for the brake linkage, and turn your servo around backwards (so the horn is on the front)
Just make sure that your carb is angled parallel with the linkage for the carb slide.
hope that helps
T-BirdJunkie is offline
Old 03-19-2005, 12:21 PM
Thanks T-bird
I didn't think of turning the servo around.
Old 03-19-2005, 12:29 PM
Good luck, let us know how it works out.
Old 03-19-2005, 12:34 PM
I will thanks again.
Old 03-20-2005, 01:06 AM
Bud
Here's a pic.
Bud is offline
Old 03-20-2005, 01:10 AM
Bud
Another one. I don't know if you'll be able to see the detail in it. you might have to put it into a photo program and make it bigger. Worth a try anyway.
Bud is offline
