Trinity D8 4x12 1/8th scale motor
http://www.trinityrc.net/shop/index....ory&path=72_73
I asked this question on the trinity revtech thread with no response . Has anyone ran these motors and give an opinion on them ? I have had good luck with the old brushed motors the duo 1 and the new revtechs . Now im looking to 1/8th scale but theres not much on these motor Info wise or forum wise . Being a trinity I usualy would buy it anyway BUT I remember the nemesis /pulse line of motors , they was impossable to run and make enuff power to keep up . Just a bad design . Anyway any input would be great thank you. I will be putting mine in a truggy btw.
Forgive me for straying off topic. I have no experiance with the D8 motors but I wouldn't hesitate to run one at all. The Duo series of motors have been excellent for me. In fact I still have an old Duo1 17.5 thats the fastest 17.5 in my box of motors. I agree that I had a lot of issues with the revtechs and wouldn't buy another one. But I found my problem was just that I had it overgeared. The revtechs dont like to be over 130 to make power but they will scream if you put a small enough pinion on them and will stay cool. I guess I'm just currious what your problem was with the D1
Typicaly a sensored motor does not like to run sensorless and will give you some issues from a dead stop, if you are going to run sensorless I would more recomend a castle motor over a trinity.
No Comment Yet....
I run the 2100KV with a Tekin RX8 seems to run hot. I have run a few different combos and I get the same result. Also I noticed that the screws on the back of the can seem to want to loosen up. I have tightened them like 3 or 4 times in 3 races. I believe this extra heat is causing other issues also. I am running it on a Losi8E 45 Spur, 15T Pinion with Protek 50C 4S batteries. Honestly because of the lack of participation on the forums about the motor I think I am going to buy a Tekin 1900KV to see if I have the same issues.
These motors are great
I personally run the D8 1950 and it is great. The bottom end does not overpower the car but the top end is still stupid fast like a higher KV motor.
My son has the 2100 in it and it is very strong!
They run super cool.
You can not go wrong with these motors.
anyone want to share their opinions about those motors? are they rebuildable?
I have been running them...
I have been running these motors since they were in prototype and they are great motors.
I was running the Tekin motors before Epic released the D8 and I will tell you that are a great motor.
They run super cool and provide tons of power. I have found you gear them a tooth smaller than a tekin per KV as they spool up a ton more then other brands and provide blistering top speed.
I mostly run the small can 1950KV in my RC8.2 and it provide silky smooth power for an Ebuggy. Not as harsh on/off switch type of power others seem to provide.
Give them a try... You will not be dissapointed...
Not Sure
I honeslty am not sure... I would think they would run fine except they will not be as smooth on the bottom end as they could be. I mostly run them with either the LRP IX8 or my son runs his with a Hobbywing 150 Sensored.
I personally have not had the best luck with Castle stuff.
Thanks for the comment Jfuel!
at amain i only see a type of can, and they are all 74mm, so if you say that you were running the small can 1950kv, you mean that it was smaller?
Nowadays people looking for a sensored motor only have one choice: TEKIN, but there are new motors out there and nobody talks about it; like thunder power zxr8 (i own a 1900kv), the new orion mr8 and those team epic that looks so good.
