Tire Balanceing
Old 04-30-2012, 10:03 AM
Maxthepersonz's Avatar
Trader Rating: 20 (100%+)
Default Tire Balanceing
Has anyone noticed significant changes from doing this? Is there a way to do it without buying a balancer?
Maxthepersonz is offline
Old 04-30-2012, 10:07 AM
hoofer's Avatar
Trader Rating: 36 (100%+)
Max i have one!!
Chuck
hoofer is offline
Old 04-30-2012, 10:13 AM
Originally Posted by hoofer View Post
Max i have one!!
Chuck
Ah so all you guys balance yours?
Old 04-30-2012, 11:11 AM
hoofer's Avatar
Yes!!
hoofer is offline
Old 04-30-2012, 11:21 AM
tc5 man's Avatar
You might laugh at this but heres what worked pretty good for balanceing my tires and thats using your front carrier without the axle bone just the bearings and the axle cup . Make sure the bearings are clean and free and oil them them up there will be some back forth play . Make sure your axle cup is not to wared out though. But this method works give it a try its a El Cheapo but effective way to balance the tires !
And for sure you will notice a diffrence when balanceing the tires for sure if your running Truggy tires its really noticeble for sure !
tc5 man is offline
Old 04-30-2012, 08:08 PM
ta_man's Avatar
Trader Rating: 162 (100%+)
Lets put it this way: 40 years ago when I was running HO & 1/24th Slot cars, I used to balance those tires. So yes: I balance my RC car tires.
ta_man is offline
Old 05-01-2012, 06:36 AM
Ordering myself a balancer! The axle method you were talking about makes complete sense though. Its basically the same thing.
Old 05-01-2012, 06:58 AM
Team Grid RC's Avatar
Try running with a set of balanced wheels and a set of unbalanced wheels, you will noticed a difference how much smoother it runs with balanced wheels.
The imbalance on touring car tires is so slight but very noticeable at high speeds since these are smaller diameter tires and need to rotate at higher rpm compared to truggy tires.
Although the only drawback on balanced wheel for off-road, as the tires gets clogged up, the balance is off anyways. If you are running a clay or clean track surfaces, balanced wheels do make a big difference.
Team Grid RC is offline
Old 05-01-2012, 07:08 AM
Pulse_'s Avatar
This post is a good occasion to have some feedback on 1/8 wheel balancers on the market. These are the ones I know, I just don't know which one to choose
TEAM GRID
dynamite
dubro (needs an adapter)
AKA
LOSI
RB
MUCHMORE
FASTRAX
HUDY
ULTIMATE RACING
Pulse_ is offline
Old 05-01-2012, 07:14 AM
hoofer's Avatar
I have & use the dynamite!! works perfect, Max you can use mine, any time you want!!
Chuck
hoofer is offline
Old 05-01-2012, 07:26 AM
Pulse_'s Avatar
How often do you balance your tires? The foam moves inside the tire sometimes no?
Pulse_ is offline
Old 05-01-2012, 07:31 AM
hoofer's Avatar
I check once a month, or after a big crash
Chuck
hoofer is offline
Old 05-01-2012, 07:49 AM
Trader Rating: 55 (97%+)
Big crash??? huh?
shagnat is offline
Old 05-01-2012, 08:24 AM
Cpt.America's Avatar
Trader Rating: 52 (100%+)
The inserts shift inside the tires all the time. I check my balance every race day. Usually they are still spot on, but sometimes one or more will be off.
Cpt.America is offline
Old 05-01-2012, 08:31 AM
hoofer's Avatar
Originally Posted by shagnat View Post
Big crash??? huh?
Sometimes i push a bit too hard!! (LOL)
hoofer is offline
