Tekno RC EB48 Thread
#8926
As I said in my previous post, I had to mod the spur gear, and whenever I use a plastic spur, I will use black sealant on one side of the paper gasket so it will seal right.
#8931
Do they come in the eb48.2 kit?
also, 2 of my shocks the piston are not smooth.
and I bought the opt. 8.1.3 tekno piston and two of them are not smooth
did i get some bad pistons?
I may have to sand two of the pistons down the opt ones that is...
#8932
I did not get any white pistons I got the Piston on the tree.
When u cut off parts tree yes u may need to sand nub but idk why whites 8x1.3 would not be smooth?
#8933
Haha I'm so confused... I think I thought you were asking if the optional 8x1.3 pistons come on a parts tree, which no they don't. .2 comes with black pistons on a tree I think they're 10x1.2.
the white piston two of them.
I will run them and see if they loosing up
#8934
What servo horn are you guys using with the hi tech 7955t servo?
#8935
I am using the hot bodies servo horn it works great
#8936
So I just got my eb48.2 together. Measured everything as directed. My front camber even on the outside hole on the steering knuckle is +5*. ! Looks like I'm going to be roasting the outer edges of my tires..... Am I missing something here? Any help is appreciated!
#8937
#8939
Do you have a .1? Hard to tell you without pics, if u post a couple w wheels off I'm sure we could help. And I'm finishing my .2 build tonight so ill let u know if I have same results but this is my 3rd tekno kit in 6 months so i already know where everything goes mostly.
