Tekno RC EB48 Thread
#3016
If your able to run a higher cell and a lower KV motor it will be efficient more so then running g a lower cell and a higher KV motor.
If your looking for a ebuggy also take a look at the serpent 811E its a awesome platform as Tekno check out the thread its also a true ground up manufacturered ebuggy not a conversion.
#3017
Doesn't surprise me that the cars got into doing this. I fly giant scale RC aerobatics as well , and the same principle applies when we are running 6S , 8S , 10S and even 12S setups on some of our bigger birds. The higher the cell count , the more efficient it is. Makes me happy to hear that the RC car part of the hobby finally realized this.
This seems like a pretty impressive buggy for sure. I've got a lot of reading to do in this thread. And since I live up in Oregon ( with no indoor tracks any more )......I won't be in a hurry to pick something up.
Sold all my old Kyosho Kanai 3's years ago and kept all my really , really old Mugen MBX4-XR works buggies.....don't think I would have the heart to ever sell them. I have 4 rollers with enough parts to run that dang buggy for the next 10yrs hehe. Just need something newer though.
#3019
1. Steering Rack durability
2. Steering rack clearance under front brace.
3. Minor binding in front hub carrier and hubs
4. Front hub screws were too long (has been corrected)
5. Drive cup wear*
6. #3 leading to rear gear box input bearing failure
7. Motor mount flex doesn't allow use of plastic spur with Traktion drive
8. Some had trouble building the shocks(skip the o-ring on th cap).
9. Front and rear upper links need shorter turn buckles (very hard to thread plastic ends on all the way.
10. Slight clearance issue with spur gear and diff stop plate.
11. Slight issue with spur gear not seating on diff case.
12. Correctble issue with diff spider gears-don't use the shims.
13. Some thought the gears were loud, but that is how straight cut gears sound.
14. Stock servo horn breaks easily
Compatibility Issues:
1. Novak Activ8 doesn't fit
2. HobbyWing's bigger ESC's may or may not fit
3. Futaba FASST receivers are a tight fit
4. Some servos needs extensions to reach receiver
5. Taller servos may rub servo horn on underside of body
5. Drive cup wear*
#3021
Thanks man! I guess things changed more than I thought. I was looking at some of the KV ratings on some of these newer esc/motor setups....and that's what got me thinking about the 2S question. So 4S is the standard at race events and so forth now days? And something like a decent 4S on a T8 1900kv or 2050KV motor is still pretty strong?
Jeffro
Its a bit of a drive for you but we have a pretty cool outdoor 1/8th track up here in marysville, WA. It is called J&S hobbies. If you get a car you should come to one of the bigger races.
#3022
While I will say the Serpent cars are high quality and well engineered , I have seen 2 racers in my area say they didnt like them and they were looking to switch to a differnt car as they couldnt get the 811E to hook up .....
#3023
Marysville has an MX track too! I haven't been there yet , but have plenty of buddies who have.
#3024
Here is some video of me and my buddy Joe B. running our EB-48's this past weekend. My car was running great until a backmarker flipped me when i was in the lead. I was .01 off of TQ when it happened. Joe had his car shut off but got it running again towards the middle of the race. I am the orange car and he is the silver.
http://www.youtube.com/watch?v=rCJLS...ature=youtu.be
#3027
Here is my main. I qualified 8th in the A main. Tires were the wrong compound but all I had. Car was a little on the loose side so I drove safe. Fast forward to the 2 minute mark. It took them a while to start the race.
http://www.youtube.com/watch?v=s5GtD...ature=youtu.be
#3028
#3029
I had to be gentle on the throttle. I ran j concept mega softs as its all i had left. It was wayyyyyy too soft.lol literally could pull on the tire and stretch it abot an inch and a half.lol. The car ran great all day. I want to try to mess with the speedo as i really was getting yanked down the straight. Love the car though. It was best in my second qualifier with the right tires. Thanks for watching the vid buddy.
#3030
Im running a tekin 1900 rx8 i could use a little more top end on the straights im already at a 17 tooth, but for a battery im running a 20 run gens ace would a good 4s pack help enough and any good deals out there on 4s pack i was looking at that one on stormers home page
