Tekno RC EB48 Thread
#2806
#2807
#2808
i haven't seen tyler vick drive e-buggy in a while so i can't say. as for weasel, i don't think it's any faster than chris'. his buggy is fast. now driving it? well, let's just say weasel is very talented. me and chris? we're not on his level. but for pure speed/power, chris' buggy is FAST.
#2809
Yeah anyone can build a fast car, very few can wheel them.
#2812
What oil and pistons were you running? Sounds like maybe you were undersprung and the shocks could not rebound. Usually if you go to way stiffer springs you have to make a dampening change too, unless your dampening was way off to begin with. Where did you get your pre-mugen spring setup?
I was just experimenting, I had originally though that the buggy was over sprung in front. I had calculated the rate of the rear springs only to find the calculated rate to seem too low. The calculations were very unbalanced front to rear. I went a little heavier in front, and a lot heavier in the rear. I figured the rear traction would go away. I was shocked to find that it was better. The only negative was that it now had an on-power push, and was skating around at low speeds, as expected.
I would normally have changed dampening too, but you should only do that if the setup you have is working OK. The dual change will change how the buggy works in a bumpy vs jumping kind of relationship, if you get my drift.
The thing that surprised me the most was that the leaned-in front shocks made such a difference in low-speed traction. The push was gone, and the car just squirted from corner to corner. I was loving it! I ordered the Tekno springs because the rates are better suited to this lighter-weight buggy.
This illustrates that the buggy is very responsive to setup changes, but not overly so.
How many times have you changed something small before a race, just looking for a slight improvement, only to have the car go to crap. This buggy shouldn't give those kind of surprises.
Bravo, Tekno!
#2814
I've got all my electronics purchased, last thing to buy is batteries, and i want to make sure that i get packs which counter balance the electronics most evenly..
I thought Danny mentioned something on the tekno site to help with this. I can do it myself by making some assumptions, measurements, and CoG equations.
#2815
Does it seem to hit an equilibrium at 150 with that gearing, or if you ran an extra 5 minutes would it come off even hotter?
With my skill level, I often prefer to give up a little speed/power to have slightly lower temps, such that I can run and run without worrying about burning up a motor (also goes back to my cheapskate nature, I hate burning up components/breaking parts). Speaking mostly to practice sessions. During a race I will probably use your gearing either way.
Joey
#2816
My electronics are as follows:
Mamba Max Pro (81g)
Tekin T8 1900Kv (341g)
Radiopost Servo (65g)
Mylaps Transponder (7.8g)
Joey
#2817
I am running 40wt front and 35wt rear Associated oil with Associated 5x1.1-5x1.2 pistons. The spring setup was the stock springs.
Bravo, Tekno!
Bravo, Tekno!
#2818
It will run that way through a full 5600 pack.
Chris,
Joey
Joey
