Tekno RC EB48 Thread >
Like Tree2Likes
Old 09-04-2012, 02:23 PM
  #2266
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
Ha!
Originally Posted by protc3
Grab a set of hinge pin inserts also. You take out a hinge pin and the insert goes with it. Im not only the bent hinge pin president but Im also a client.
Here's what I put in my spares box:
Inner Hinge Pin Set (2)
Rear Suspension Arm Set (2)
Front Suspension Arm Set (2)
Steering Spindle Set (2)
Spindle Carrier Set (2)
Steering Turnbuckle Set (2)
Camber Link Turnbuckle Set (2)
Composite Spur Gear
Rod Ends (6.8mm, camber links)
Rod Ends (brake/steering/sway bay linkage)
Hinge Pin Inserts, Wheelbase Shims
That pretty much covers all the plastics and turnbuckles in the suspension. To be honest, it's more like a rebuild kit. I'm hoping that I won't need any of it.
ChrisAttebery is offline
Old 09-04-2012, 02:29 PM
  #2267
protc3's Avatar
Yeah, The only thing I broke so far was an arm. Unfortunately it took out the hinge pin and the insert. Im pretty sure im not supposed to hit the light pole coming off a tripple. Sad part is, I did it on my 1st lap with it when it was brand new. I havent broken anything since. I normally do not crash much. I was trying to get a feel for the car and wound up getting a feel for the light pole.
protc3 is offline
Old 09-04-2012, 02:47 PM
  #2268
sramos's Avatar
bahahahahaha classic!!! thats funny lol
sramos is offline
Old 09-04-2012, 02:49 PM
  #2269
sramos's Avatar
Originally Posted by ChrisAttebery
Ha!
Composite Spur Gear
be nice if they sold a spare/just incase kit like this at a discount
sramos is offline
Old 09-04-2012, 03:03 PM
  #2270
SourDieselX's Avatar
It's been awhile and I'm sure there are other sub forums where this is discussed, but for those who have this eb48, what Lipos are you using, I'm going to be running a RX8 w/ Tekin 1900kv, looking for a good 4S, so i'm curious what everyone else is using.
SourDieselX is offline
Old 09-04-2012, 03:12 PM
  #2271
Tech Legend
Cain's Avatar
Trader Rating: 293 (100%+)
anyone fit a Speed Passion Silver Arrow in the buggy?
Cain is offline
Old 09-04-2012, 04:04 PM
  #2272
kufman's Avatar
Yup, that's what happens when you let an on-road guy try to drive offroad... lol! jk
kufman is offline
Old 09-04-2012, 04:48 PM
  #2273
sramos's Avatar
same motor and esc w/ thunder power 5300mah 65c 4s........bit expensive but awesome. running 18 tooth pinion with 80% current limit. coming off of 10 min main around 170-175 degrees. im sure once i start learning it and driving harder ill need to take limit down a bit. maybe to 74-76%. i like seeing my motor around 160-175ish. tekin doesnt like seeing their motors above 180. i will say watch how long you practice tho....i wouldnt go over 10 min cuz ive seen my motor get pretty hot after 12-15 min. if your mains are longer then 10min then obviously turn limit down or gear accordingly......im just a rookie that reads alot of forums etc to learn more.... and thats my 2 cents
sramos is offline
Old 09-04-2012, 04:50 PM
  #2274
Tech Legend
Cain's Avatar
to be honest I don't think I have gotten any of Tekins 1/8 motors in buggy over 160. But I use the gear to the longest straight method, low as possible timing settings, etc.
Cain is offline
Old 09-04-2012, 04:54 PM
  #2275
sramos's Avatar
i should do the same but i guess im to lazy to change pinions and mesh etc. lol. so i just do my CL
sramos is offline
Old 09-04-2012, 05:33 PM
  #2276
Trader Rating: 70 (100%+)
Quick question.
Step J1 - the rubber o-ring gets squeezed out every time i tighten the servo saver. Is this common? Can i run it without the o-ring?
Krafcik is offline
Old 09-04-2012, 05:36 PM
  #2277
teknorc's Avatar
Originally Posted by Krafcik
Quick question.
The o-ring should be inside the groove of the adjustment nut and shouldn't squeeze out.
teknorc is offline
Old 09-04-2012, 05:56 PM
  #2278
And how tight should the center diff be before it's broken in? Turnable with some major effort?
it also feels as if their is some wobble in the center diff, like the hole for the bearing/shims is not square.
Krafcik is offline
Old 09-04-2012, 06:04 PM
  #2279
I am running the same ESC and motor as you with a Protek 4100. Lots of battery for a 10 minute main.
-Kane
Kane-o is offline
Old 09-04-2012, 06:07 PM
  #2280
jf45's Avatar
Trader Rating: 92 (100%+)
Ready to hit the track.
This was the smoothest build I ever done. Every thing fit perfect and the quality is top notch. Its clear there was a lot of thought put into this buggy.
jf45 is offline
