Old 02-02-2005, 12:47 PM   #1
Send a message via AIM to thumpin15s
Default just out of curiosity, what would happen if you run unleaded gas?
What would happen if you ran unleaded gasoline in an RC car? Would it even run? I would never try it, just kind of curious as to why they dont use normal gas.
thumpin15s is offline   Reply With Quote
Old 02-03-2005, 02:13 AM   #2
Aaron Waldron's Avatar
It won't run.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 02-03-2005, 11:26 AM   #3
edseb's Avatar
Also, because you have a 2 stroke engine, you need some sort of oil mixture or your engine won't be lubricated. That's just the first problem.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 02-03-2005, 11:46 AM   #4
Jack Smash's Avatar
Trader Rating: 29 (100%+)
You'll have the same issues that people have when trying to convert a gas full size race motor to methanol. The carbs are setup for a methanol based fuel. Mixture, veturis and porting would be all wrong. Plus gas burns hotter than methanol so expect a 20 to 40 deg increase in temperature.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 02-03-2005, 08:43 PM   #5
I'm pretty sure you'd never get it to work. I have never heard of anyone using gasoline in a diesel-style engine where compression is what ignites the fuel instead of spark.
www.liverc.com
Old 02-03-2005, 08:48 PM   #6
how does compression ignite the fuel though?
Old 02-03-2005, 09:03 PM   #7
Dill's Avatar
compression of the mixture creates heat. The same holds true to our earths core, which is molten due to all the pressure placed on top of it. Pressure=heat=combustion
Dill is offline   Reply With Quote
Old 02-03-2005, 09:13 PM   #8
That is how diesel engines run (our model engines are basically a small diesel). The glow plug serves to facilitate ignition to start the engine, but regular running requires compression to ignite the fuel. That's why our engines won't run without an igniter once they wear out.
www.liverc.com
Old 02-03-2005, 09:26 PM   #9
so basically the glo plug just gets the heat going? So your saying if you could somehow (this is just theoretical (sp?)) take the glo plug out, and keep the compression, it would still run? I guess so though, because the glo plug only gets heat when an igniter is on it. Well, things are making more sense now lol. so this is basically why deisels are indestructable lol. (and can like drive through water and stuff without stalling)
Old 02-03-2005, 09:30 PM   #10
Exactly.
The glow plug still does get hot during compression, which is why the glow plug temperature can change how the engine runs. Theoretically (although probably not in practice), taking the plug out while keeping the combustion chamber sealed, the engine would still run.
www.liverc.com
Old 02-04-2005, 12:50 AM   #11
OvalEvader's Avatar
Send a message via AIM to OvalEvader
Its the air compressing that makes the heat to ignite the fuel, not the fuel itself.
OvalEvader is offline   Reply With Quote
Old 02-04-2005, 01:02 AM   #12
Good call. Liquid doesn't compress (to a point).
www.liverc.com
Anyone ever have this happen? itspat Monster Trucks 2 02-06-2007 02:05 AM
what will happen!!! benste Electric Off-Road 4 12-12-2006 01:51 PM
Just for curiosity sake lazarus Electric Off-Road 3 08-26-2005 06:28 PM
Purly out of curiosity The Black Kat Rookie Zone 28 06-28-2004 12:33 PM
what will happen if I put a Aluma Electric On-Road 6 02-04-2003 03:11 PM
