From Bash to Course
For the first time in 5 years, I decided to take my RC8be to a track. I had a great time on the course and I am considering more trips and possible entering into a race. My car is set up for speed because all I did was run it up and down my street or at a huge grass field. My question is regarding my current gearing setup. I have a 44t spur and a 25t pinion on a MMM 2200kv motor. Is that ideal for a short course or what should I change it to to make my car run efficient and less stress on my motor. Thanks!
Originally Posted by Brazie
(Post 10625029)
What about lipo's...i been using 4s when i bash. when i went to the track my friend told me 2s is perfect and 4s ill be way overpowered. so i went with 2s. 2s on my mmm 2200 kv 44/25 gear setup. Tonight ill be going to a track that is bigger and my friend says that i can use 4s with my setup. In all honesty, on a track I am comfortable with just using 2s now. i just want to make sure that it is not in any way damaging or wearing my motor down more than it normally would.
What kind of radio do you have? If you can adjust the endpoint for the throttle, then do it. That'll allow to control the top-end of the power, great way to keep you out of trouble, and learn the buggy on the track.
I'd run it 4 cells though, the buggy was designed to have that much weight in it, and you'll likely kill any 2 cell you put in it, unless you take it easy. |
Originally Posted by Vegatron75
(Post 10625956)
Originally Posted by AssocRacer
(Post 10625452)
When I ran my RC8B converted to electric at a fairly small indoor track with a Tekin 1700 I was using the spur that came with the conversion kit and like a 15 or a 16 tooth pinion. 25 is probably WAY to high for even larger tracks. I would start around a 16 tooth for the 2200. Keep in mind that that motor is going to be RIPPING fast for a small track.
Thanks! |
Wow. With constant use on 25/44 gearing, I'm surprised that motor is still going. It must've been getting pretty damn hot?:eek:
Anywhere, between 15t-18t for the pinion should get you the right gearing. |
Originally Posted by RatsacK
(Post 10626357)
| All times are GMT -7. It is currently 10:12 AM. |
