stampede 4x4 too hot
I recently got a new vxl motor of my stampede, first day assemble it back together ran it and the pinion gears melted. i was running it offroad , next day i install new pinion gear ran in the street see how it reacts. about 10 minutes of running on the street little bit on front yard grass motor was very very hot, esc was hot, pinion gears felt like it was going to melt soon if i keep running it. also to loosen up and tighten up the clutch see if there was a different. motor too hot, clutch and pinion was also very hot. can someone tell me what i should do next.
thank you
thank you
thank you i will check back with everything. stock 54t and stock pinion.
what is the best gears and pinion for offroad running, i want to keep everything in low temperature.
Iwill probably post up a picture and video soon. there is also this high whine sound.
what is the difference between each cell to consider it a bad lipo? i have 2s 4.17v and 4.2v
