TRAXXAS VXL vs CASTLE MAMBA MAX PRO >
Old 04-08-2012, 06:15 PM
Default TRAXXAS VXL vs CASTLE MAMBA MAX PRO
I have the VXL system on my 2wd slash. Its pretty nice but always room for more power/speed. I mostly bash with friends and race around doin jumps ect.
What would I gain from the Mamba Sys. Is it worth the money for the improvements it will give me?
SickS/ash is offline
Old 04-08-2012, 06:22 PM
8ight-e's Avatar
Trader Rating: 58 (100%+)
EDITS: (thank the guys below) A MMP esc would give the ability to run sensored motors but for raw speed and bashing it doesnt mean much. It would give you options to run up to 6s lipo for some crazy times... with the right motor choice of course.
If you got the castle MMpro with the 1410 (combo) you would have endlesss torque and could gear up as high as you can fit and can keep your current packs.
If you just need a little more consider 3s if you are only running 2s on the velineon, you would be surprised how much it wakes up for bashing and play on 11.1v.
8ight-e is offline
Old 04-08-2012, 06:29 PM
Originally Posted by 8ight-e View Post
A basic "mamba system" (4600,5700, etc) wouldnt get you much and may even run hotter than your velineon, you could always run 3s lipo if you are not already (to get more out of your current).
If you want to simply increase speed stay with your velineon esc and get a castle 1410 (3800kv). This is a 4 pole motor that can be geared in a slash as tall as you can fit, really drive up the speed.
If you got the castle pro with the 1410 you would have all the gains mentioned but if you don't change voltage it won't be any faster than the 1410 on your velineon esc.
Hope on of those helps.. sorry you left out a lot of details.
Hate this correct you on this but alot of people on the Traxxas forum have said the VXL does not like running 4pole motors.
rc10t3b4 is offline
Old 04-08-2012, 06:30 PM
RatsacK's Avatar
Trader Rating: 21 (100%+)
This won't work. Several people have said that the VXL-3S ESC doesn't like 4 pole motors (kills the ESC).
RatsacK is offline
Old 04-08-2012, 06:31 PM
8ight-e's Avatar
Could be right... I'd go with what they say. It has been 4 years since I touched one of those VXL esc's. Check w/ Traxxas first if you want to find out or read the manual to be sure.
8ight-e is offline
Old 04-08-2012, 06:33 PM
Well I do alot of Bashing with buddys and alot of the tracks I run on are more supercross style then technical. Im just lookin for the best performance overall I can get. I live in FL so i mostly run on sand/dirt. so i use alot of 1/8 badland and paddle tires. I recently got the proline powerstroke shocks and I like them as well. I think id like to slowly convert into a backslash...
Old 04-08-2012, 06:38 PM
8ight-e's Avatar
2s packs for racing, 3s packs for bashing. Just swap in and out w/ the vxl, maybe the best of both for you. At least something to consider.
If you run the mmp/1410 combo and want to go back and forth you would have to swap gearing every time you wanted to play (pain in the rear) if you keep the same voltage.
If money is no object, get the castle setup and 2s and 3s packs :P Gear 2s up for racing and just drop in the 3s for some fun (again not much different than doing that w/ your vxl).
8ight-e is offline
Old 04-08-2012, 06:39 PM
I'm a Tekin fan but for what you're doing go with the MMP SCT edition. If you want more speed just get a bigger battery.
rc10t3b4 is offline
